boost drop
Old Feb 20, 2006 | 09:15 PM
pimp's Avatar
pimp
Default boost drop
got a s2 rs it set at 15 psi but as it goes up the revs the boost slowly drops down to 11 psi any ieas???
Old Feb 20, 2006 | 10:48 PM
evander's Avatar
evander
How are you controling boost and what kind of actuator are you using. Does it do this in all gears, What does it peak at and drop back to in other gears.
Old Feb 22, 2006 | 12:30 PM
Avinitlarge's Avatar
Avinitlarge
Try attaching the actuator pipe to the charge carrier, You will have to fit a small pipe on the charge carrier though. I did this and it made quite a big inprovement
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Marv888
Sep 26, 2015 03:44 PM
Russ Payne
Sep 25, 2015 08:29 PM
