This has happened a few times now and starting to get a bit more frequant.
It'll pop with the revs dropping and stall. If you keep blipping the throttle to try keep it running it will pop.
Also then when you try starting it back up it will turn over, sometimes starting and then sometimes not evan a click. Leve it for a bit and will turn over.
Just notice a earthing strap from the body conneted to nothing else near a box just b4 the fuel filter. What should it B connected to and could this b causing the prob?
I'd personally say its a loose connection somewhere, when you say sometimes theres not even a click when trying to re-start? Can you expand a little more on that? Are the dash lights always on?
Yeah the dash lights will always come on. The engine will turn over a couple of times then when you turn the key about a third time it wont do any thing cept for the lights on the dash comeing on.
had the same sympthoms with my rst before, turned out to be a loose connection, the + connection of the battery.
perhaps yours is corroded or a bit loose?
