Full steel bottom end, when do i need it? and what to get?
Old Feb 20, 2006 | 05:02 AM
RoBoX's Avatar
RoBoX
Default Full steel bottom end, when do i need it? and what to get?
i am currently trying to sort out the spec of my engine and so i need some advice.. this engine build is a learning process for me as i am not skilled in tuning cars, i know the basic stripdown and rebuild of engines, but i haven't taken it much further before..so the basic skills and some more specific is in place, but still need lots and lots of advice..
the engine is being built so it can take a lot of abuse and power(hopefully). i want to build it so it can take around 300 hp(in time) and i want parts that have a good value for money ratio, not shite parts but not overpriced stuff if you know what i mean.. could also need advice on where to get the parts from(in the uk as prices in norway can't be compared).
so i was wondering, how far up the hp and rpm scale can the standard crank shaft be used? assuming it is in good condition and fully balanced..
what make of con rods and low comp forged pistons to use? where to get it?
if you need any more info from me as i'm sure you do please ask..
Old Feb 20, 2006 | 01:14 PM
adamS2RST's Avatar
adamS2RST
I *think* the standard crank is good for more power than that for that power you'll want steel rods, farndon perhaps? - You can get them from Burton Power. As with pistons, low comp cossie racing are usually a good option. Again Burton sell them.
That's just a guide - I don't know much either !
Old Feb 20, 2006 | 02:11 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
You can no longer get Cosworth Pistons for an RST
Old Feb 20, 2006 | 02:14 PM
RoBoX's Avatar
RoBoX
ok, so the original crank is good enough for these powerlevels?
@tony turbo, you got the power levels i was wondering about, any possibility you could give me your bottom end specs or are they secret?
Old Feb 20, 2006 | 02:15 PM
Tony Turbo's Avatar
Tony Turbo
Depends on what you want to know exactly...
Old Feb 20, 2006 | 02:19 PM
RoBoX's Avatar
RoBoX
especially if you have a steel crank? also interested in makes of rods and pistons.. compression ratio with the pistons used and so on.. if you want to keep some of the spec a secret i completely understand..
Old Feb 20, 2006 | 02:21 PM
Tony Turbo's Avatar
Tony Turbo
New standard crank
Fardon Rods
Custom made Ross Racing Pistons
I hope that is of some use to you
Old Feb 20, 2006 | 02:43 PM
RoBoX's Avatar
RoBoX
thats great tony.. at last i got the crank question out of the way.. have been thinking about that for some time now..
btw: do you know if christian&becky is running standard crank too? just thought i'd ask.. similar power in his engine too isn't it?
Old Feb 20, 2006 | 03:57 PM
adamS2RST's Avatar
adamS2RST
- Ignore me then I should have known
Old Feb 20, 2006 | 04:56 PM
Tony Turbo's Avatar
Tony Turbo
I'm sure Mr C won't mind me saying that our engines are the same, exept for cam, turbo and inlets.
Adam - Don't worry about it mate, we tried for ages to get some and couldn't get them anyway unless we got X amount of people to group buy them into re- making them
Old Feb 20, 2006 | 05:38 PM
gus's Avatar
gus
i have a standard ford crank but then had it knife edged,tuftridedand lightened and balanced
Old Feb 20, 2006 | 06:31 PM
adamS2RST's Avatar
adamS2RST
Only heard good things about Ross Racing though !
Old Feb 20, 2006 | 07:11 PM
RoBoX's Avatar
RoBoX
thank you tony..
will be looking into the rods and pistons you said..
@gus: what does it mean to have it knife edged?
Old Feb 20, 2006 | 07:32 PM
Tony Turbo's Avatar
Tony Turbo
Yeah, they are a good piston, made much better than the Cosworth ones were and not alot of difference in price too. And they can be custom made so as long as you know the dimensions you need you are laughing.
Old Feb 20, 2006 | 07:42 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Who is Ross Racing, only heard of them through reading on here........
Old Feb 20, 2006 | 07:43 PM
Tony Turbo's Avatar
Tony Turbo
Look on Google you lazy git They make alot of Nascar pistons...
(P.S. Bought a gun yet? )
Old Feb 20, 2006 | 08:25 PM
adamS2RST's Avatar
adamS2RST
Old Feb 24, 2006 | 08:13 PM
Charlie Chalk
Unknown.
Will do
And no not yet
Old Feb 25, 2006 | 02:33 AM
Combi_Chris's Avatar
Combi_Chris
how long has that been the case ?
Nov 5, 2015 08:12 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Nov 3, 2015 04:08 PM
Ben26
Sep 3, 2015 07:55 PM
turbowag
Sep 3, 2015 08:07 AM
