Tesco Fuel
Not sure if this been posted before but they do 99octane fuel now, thats better than optimax aint it
Filled my cossie up with it just before I broke it DOH!
Take a look at the fifth gear tests if they are any help
http://fifthgear.five.tv/jsp/5gmain....143&pageid=275
On ordinary unleaded the Impreza put out 235 bhp.
On BP Ultimate, it managed 248 bhp.
And on Shell Optimax, it offered 249 bhp.
Ordinary unleaded gave the lowest torque with 232 ft lbs.
BP Ultimate produced a much healthier 248 ft lbs, and
Shell Optimax was even better, producing 258 ft lbs.
Originally Posted by PeterLucas
mon levels? what they?
i thought it was just down to octane rating? meaning how well/efficiently it burned?
Unless you can advance the ignition timing on your car or have an 'active' knock sensor than can advance the timing you wont really see much gains at all
pmsl at people quoting specific horsepower gains, they only relate to the specific car tested in those specific conditions.
Originally Posted by 89XR2
Isnt it true though that all the big petrol companies tankers just fill up wherever is closest so its not the exact same fuel in the pumps all the time?
ok guys, as a tunner will tell you if your car is set up to run on unleaded then thats what you should put in, if your cars been chipped and set up to run on super unleaded then thats what you should put in ..common sense realy
mine was set up for super and says it on the paper work from m.s.d at the bottom of the receipt, thers no point in putting optimax or any other super if your cars set up for unleaded
andy
andy
andy
andy
its all to do with ignition timing! whats the point in using super if your timing is set up for unleaded
andy
andy
Sorry chap i know what your saying but it doesnt apply to ALL cars
andy
andy
Originally Posted by MattRS1600i
Only two things you can do on an N/A car to take advantage of higher det resistance, raise compression ( bit difficult without rebuilding it..lol ) or have the ignition timing altered either via chipping or if your car has an active knock sensor and can advance ignition itself....it's been said about three times now, how hard is it to understand?
Originally Posted by NUTS RuS
Buy your food from Tesco and your fuel from Shell IMHO
http://www.greenergy.com/products/99_octane.html
Optimax is guaranteed to be a minimum figure, even at the pump. Tesco's is a manufacturing figure which by their own admission will differ at the pump.
The Tesco stuff used for motorsport (which it is pushing by advertising) is made specially from one batch so its consistant. It has to be ordered in advance. That tells us all something
Thing is though, do they? I've heard everything from Optimax having a v short shelf life and by the time you buy it in some circumstances it's below that figure to BP being the most stable out of them all. Does anyone ACTUALLY know or are they all basically the same
they did a test in performance ford a while back and they said the same sort of thing
1, optimax
2, ultimate
3, tesco
mind you, each of the cars were mapped to run the best they could on the fuel they had in their tanks, and best to worst was in the region of about 40 brake
1, optimax
2, ultimate
3, tesco
1, optimax
2, ultimate
3, tesco
1, optimax
2, ultimate
3, tesco
Originally Posted by D19 STE
Did this car survive that jump
It was re-panelled up. It's the 2nd car you can see in Doug's press article Interesting how both cars wanted to be No 1 for the photo shoot
