Engine Coolant Temp sensor - failure symptoms?
Old Feb 19, 2006 | 05:30 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Default Engine Coolant Temp sensor - failure symptoms?
as above...what are the symptoms for failure? Its been suggested to me that this might be causing my engine stutter.
When my car has warmed up the car can stutter on throttle. you can see from the fuel pressure gauge that pressure drops to zero. back off the throttle slightly and you can watch the pressure climb and then its ok until the next stutter!
when this happens the fuel pump also gets very noisy
thought it was fucked but i put on a new GpA badboy yest and its still the same!
rah
chop
Old Feb 19, 2006 | 05:32 PM
Mike C's Avatar
Mike C
The Special One
sounds about right, had one go very recently on my Zetec, similar symptoms, changed it and all was well
Old Feb 19, 2006 | 05:34 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
hmmm interesting! did your pump get very noisy too?
Old Feb 19, 2006 | 05:35 PM
Mike C's Avatar
Mike C
The Special One
noisy than usual, but not VERY noisy, no
Old Feb 19, 2006 | 05:42 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
interesting! im gonna get a new sensor sorted tomorrow. i hear its a bitch to get to tho
Old Feb 19, 2006 | 05:52 PM
abdr500's Avatar
abdr500
sounds more like you fuel presure regulator or a blockage some were on the fuel side
Old Feb 19, 2006 | 05:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: Engine Coolant Temp sensor - failure symptoms?
rah
chop
Pressure drops to zero?
If that genuinely happens then either:
1) The regs fooked.
2) Pumps fooked.
3) Pump wiring no good or the lines are restricted.
4) Blocked fuel filter.
5) Intake to pump blocked.
I dont see ANY other possibilities at all.
Old Feb 19, 2006 | 06:02 PM
Butch.'s Avatar
Butch.
theres always something wrong with a cossie
Old Feb 19, 2006 | 06:03 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
rah
chop
1) The regs fooked.
2) Pumps fooked.
cheers for reply stu...
yes you can watch pressure slowly drop on the gauge until you back off the throttle a touch and then it builds back up.
1. i was presuming the reg was ok because the pressure remains high on the gauge well after you turn car off. would this mean the reg was ok?
2. brand spanking GpA pump
3. next option...
4/5. could it really be that? car is PERFECT until its been run for 15mins or so. can boost as much as you like. then pump gets noisy and stutter appears.
any more thoughts?
Old Feb 19, 2006 | 06:07 PM
rah
chop
1) The regs fooked.
2) Pumps fooked.
3. next option...
any more thoughts?
No Pal, the little valve in teh end of teh pump is the one way check valve, the reg has no effect on pressure over time, only momentary pressure at given manifold depressions and pressures.
Fuel inlet, may be collapsing when the depression goes high, sometimes the inner skin may be collapsing internally, bit like an RS turbo intake hose if you follow from your old bean tin days yeah?
Why am i getting the feeling this car has NEVER had a new fuel filter here?
Old Feb 19, 2006 | 06:13 PM
davidreader5's Avatar
davidreader5
HI,
Agree as above check your regulator 3,bar @ idle 3.5 with vacuum
pipe off, CTS would cause the engine to run either to weak or run rich,
and then cause related problems, you need to sort the fuel pressure
out before you melt the engine as the AFR must be all over the place.
Dave R.
Old Feb 19, 2006 | 06:30 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
rah
chop
1) The regs fooked.
2) Pumps fooked.
3. next option...
any more thoughts?
No Pal, the little valve in the end of the pump is the one way check valve, the reg has no effect on pressure over time, only momentary pressure at given manifold depressions and pressures.
haha i remember collapsing beantin hoses
so a new filter it is! another thing to tick off the list!
Old Feb 20, 2006 | 10:32 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
anymore input today?
Old Feb 20, 2006 | 10:44 AM
No more to give.. ive given you a definitive list of what is likely to be wrong.
Old Feb 20, 2006 | 10:57 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
sorry stu wasnt just harping on at you
just incase anyone else had the same prob.
cheers tho.
im off to ford for a fuel filter soon and going to change the above sensor anyway. want as many new parts on the car as possible
cheers
chop
Old Feb 20, 2006 | 11:09 AM
That sensor cannot have any bearing on fuel pressure, only injector duration.
Old Feb 20, 2006 | 11:39 AM
Jim Galbally's Avatar
Jim Galbally
save your money for the sensor and spend it on stuff like new rubber fuel lines or something
here's a thought... check the metal fuel lines under the car... i've seen them squashed where theyve ben jacked up on the fuel lines, or smashed down a bumpy road etc. it can happen.
Old Feb 20, 2006 | 12:11 PM
rapidcossie's Avatar
rapidcossie
how easy is it to change the fuel filter?
when removing it will the fuel pour all over the place or will it stop at the pump etc??
was going to give it a bash on my own and was wondering if i should run the tank dry first??
Old Feb 20, 2006 | 12:16 PM
rstoughy's Avatar
rstoughy
Fuel should stop at the pump
Should take 30mins top but make sure you replace the copper washers
Old Feb 20, 2006 | 12:17 PM
rapidcossie
where do you get the copper washers??
ford?
Old Feb 20, 2006 | 12:22 PM
rstoughy's Avatar
rstoughy
I would guess that you get them form Ford but i just used ones out the box at work
Old Feb 20, 2006 | 12:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
ignore that top advice at your peril
Old Feb 20, 2006 | 01:04 PM
rocky_robin's Avatar
rocky_robin
Did you? Funny that my clothes were petrol drenched and had to take 2 showers to get the petrol off me! lol!
Looking about my books here at work, I can see that that filters on yer car are cleanable. Guess it has a screw lid, with a removable mesh.
Gesh! Just stuck my clothes in the wash yesterday on the 'get rid of the petrol smell' wash as well.
Old Feb 20, 2006 | 01:16 PM
Redkop's Avatar
Redkop
rah
chop
Chop, don't you remember, you were in my car at Croft when my car showed the symptoms.... stuttering and missing, because of a duff coolant temp sensor. Got it changed and it was fine after that.
Old Feb 20, 2006 | 01:20 PM
St3V3_C's Avatar
St3V3_C
Don't you think Stu might know a thing or two about these cars
Was your fault coupled with a fuel pressure gauge showing dropping pressure at the same time as the stuttering?
No? Thought not
Old Feb 20, 2006 | 02:00 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
No? Thought not
thats a bit harsh mate and no need really. lynne wasnt dissing stu she just gave some personal experience. A couple of other people suggested the sensor including 2 trained RS technicians who have been at ford 25+years.
cheers tho lynne. gonna change the sensor anyway. cant hurt.
chop
Old Feb 20, 2006 | 02:02 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
haha sorry
*note to all*
robin is my friendly mechanic and just as well he knows what he's doing because i dont have a fuckin clue
my clothes are still in the garage
Old Feb 20, 2006 | 02:07 PM
Redkop's Avatar
Redkop
No? Thought not
Read the title of the thread butt breath!
I gave the symptoms I had. So bog off and butt out.... moron!
Old Feb 20, 2006 | 02:08 PM
Nope, sealed throw away alloy canister.
Old Feb 20, 2006 | 02:09 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
No? Thought not
you forgot the
chop
In all honesty though, i bet you didnt mention the falling to zero fuel pressure to them did you? If you did, they need sacking and handing a McDonalds application form.
Old Feb 20, 2006 | 02:10 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i dont know if it makes any odds stu but my car hasnt got a standard filter...
Old Feb 20, 2006 | 02:13 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
chop
haha i did explain it actually
its a guy i know well and not some random i spoke to at ford
when i said falls to zero im not actually sure its ever gone that far. when you can see the gauge slowly lose pressure you can back off throttle and it picks up to "normal" again. not like it falls instantly to complete zero. falls gradually.
Old Feb 20, 2006 | 02:15 PM
St3V3_C's Avatar
St3V3_C
No? Thought not
Ok, so you just wanted to post something completely irrelevant to helping him fix his fault. Cool.
But I'm the moron
Oh, and personal insults? Classy
Old Feb 20, 2006 | 02:17 PM
St3V3_C's Avatar
St3V3_C
falls gradually.
LOL.
Doesn't follow boost pressure by any chance does it?
Old Feb 20, 2006 | 02:18 PM
I stand by my opinion, anyone who knows the system well will know the CTS cannot have any bearing whatsoever on fuel pressure.
When you say its never gone "That" far.... how far has it gone?
Std is 3.5bar, idle is nearer 3, anything with boost is 3.5bar+ the boost.
The plot thickens...
Lambchop's Avatar
Lambchop
PF Idiot Sniper
No? Thought not
But I'm the moron
settle mate. to be fair the post title was just asking for what the symptoms were so she is right enough. i appreciate ANY input here!
unfortunately here in aberdeen i have NO decent garage to put the car too! wouldnt mind paying someone who knew what they were doing! i was going to find out how much a tow truck to blackpool is
Old Feb 20, 2006 | 02:19 PM
Stop arguing please people... theres far too much tension round here lately.
Lambchop's Avatar
Lambchop
PF Idiot Sniper
falls gradually.
LOL.
what do you mean? does it fall as boost increases? no it doesnt. can happen at any time any revs any throttle any boost.
Old Feb 20, 2006 | 02:21 PM
rsnissan's Avatar
rsnissan
long shot but could it be something in the tank thats causing the problem at the feed to the pump?
As the pump will be noisey if there is no fuel going through it
