cam belt
Old Feb 19, 2006 | 02:29 PM
mrjonnie's Avatar
mrjonnie
Default cam belt
Not managed to find in a search so...how much slack should there be in the cambelt. Where on its run do you check it? And how is it adjusted..
p.s are those c.ds you see advertised on e-bay for workshop manuals any good?
Thanks
MrJ
Old Feb 19, 2006 | 06:47 PM
grunter's Avatar
grunter
i have a cd yes there worth while imo as for belt slack should not be able to twist it more than 90 degrees u adjust it on the tensioner its the next pully down from the cams
Old Feb 20, 2006 | 08:36 PM
mrjonnie's Avatar
mrjonnie
Thanks for the advice. Will look for the best option for a set of cds.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
