Cossie won't start
My Saff Cos has been stood for a couple of months and I'm having trouble starting it. Can anybody suggest some things I should be checking?
Any help would be very much appreciated as I'm getting my t*ts off
few more details would help ,is it turning over ,petrol enough?have you a spark,is there fuel getting to the injecters,coil connected properly and plug leads ???imobiliser of ok??
is the petrol low as it will condence in the tank weakening it .is it reaching the injecters ,is the fuel pump primeing up first of all.Should buzz when the key is turned to second possition
The tank was empty so theres only 5 quids worth in at the moment. Do you think I should put more in? The pump does buzz. Whats the best way to check if it's reaching the injectors?
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
