Brake fluid question...
Im going to fit my AP's today & i was going to change the brake fluid to SRF but i cant get hold of any!
What alternative's are there to SRF?
& where can i get some from on a sunday?
Thanks people
Thanks people
Moondust_crust I think you might be thinking of something else.
ginge Not sure about it taking on alot of water tbh
Do i like regular brake fluid changes?... Hmmmm ... NO
But if it's gotta be done then so be it
Christian - what do you use then mate?
Originally Posted by b19bal
dont srf take on ALOT of water,,,,,,, hence the use of stuff christian uses
do you enjoy regular fliud changes,,,,,,,,, serious question btw
This is a very high performance Dot 4 brake fluid designed to perform at the extreme temperatures generated under race conditions.
It is a strong competitor for Castrol SRF.
It is noted that SRF is one of the best brake fluids available, but its major downfall is that it is very Hydroscopic, which means that it takes on moisture very easily. This results in the need for it to be totally changed every 3-4 months for optimum performance.
710 is far less hydroscopic, so can be changed less frequently. It also boasts a Dry Boiling Point figure in excess of 300°C, just like SRF.
Price is Ł10.99 per 1/2 Litre (around 1.5 - 2 litres is needed for a complete fluid change).
its cheaper too AJ,,,,,,,,,,, infact half the price,,,,,,,,,,, and we ALL know you like to count the pennies
SMILER258
Sep 28, 2015 09:04 AM
