lowering
Old Feb 18, 2006 | 11:38 PM
jimbobs_si's Avatar
jimbobs_si
Default lowering
hello people looking to lower my fiesta si on 16" mondeo wheels what tyres size should i use and how much should i lower by?
Old Feb 19, 2006 | 08:52 AM
Oranoco's Avatar
Oranoco
Tyre size you should be using 195/40/16
www.mytyres.co.uk
I wouldn't drop more than 25mm-35mm or the handling will suffer as a result. Avoid G-Max as they are beyond shonky. New standard RS dampers and Eibach springs or Koni T/A's set soft with matched springs
That's my opinion and others may well have their own though
Old Feb 19, 2006 | 01:51 PM
rodney's Avatar
rodney
will still handle ok if you stick it down 60mm just gotta learn to live with the extra bumps,.
Old Feb 19, 2006 | 03:19 PM
Oranoco's Avatar
Oranoco
60mm is way too low for 16's
Old Feb 20, 2006 | 11:33 AM
sara's Avatar
sara
sara
i want a 60 mm drop on standard rims will this scrub
Old Feb 20, 2006 | 08:59 PM
BillyCabrio's Avatar
BillyCabrio
Oranoco
What is it with the severe lowering of cars
If i take my springs off, will the handleing suffer?
Old Feb 21, 2006 | 04:47 PM
Oranoco's Avatar
Oranoco
Originally Posted by BillyCabrio
Oranoco
Problem is too many people confuse handling with cornering. Slamming the car into th eweeds will make it corner well it will however shaft the handling.
It's an arguement I can't be bothered to have so just leave the kids to it
Old Feb 23, 2006 | 08:20 AM
rodney's Avatar
rodney
kid?
Old Feb 23, 2006 | 11:53 AM
RS SHORTIE's Avatar
RS SHORTIE
Nobody said if i slam my car will it handle worse.
I think that some people just like the slammed look and not really bothered how it will handle.
More so on small powered cars as the owners like more 'show' than 'go'.
Where as on high powered cars its all to do with handlig and braking etc
As for the original post, if you want it to handle well stick with a 35 drop.if you want it to look the nuts drop it 50 -60.
Old Feb 27, 2006 | 06:26 PM
2litresi's Avatar
2litresi
i had 16 mondeo rims on my 2i it was lowered 60mm had 1954516 yoko a539 but it would be better on 1954016 but 45s give a better ride i would do it 60 they look the nuts but its up to u
Old Feb 27, 2006 | 06:57 PM
lil_ash87's Avatar
lil_ash87
Default clever clogs
if ya lower a car all ya doing is making the car stylish but also ur lowering the centre of gravity this improves the handaling of the vehicle cos are your roll axis is a different set up
Old Feb 27, 2006 | 09:24 PM
Phil DJ's Avatar
Phil DJ
My old XR2i was lowered 60mm on 16's with 45 profile tyres on. No scrubbing at all
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
