coil pack on saff cos
Old Feb 17, 2006 | 08:50 PM
2litresi's Avatar
2litresi
Default coil pack on saff cos
do anybody no who does coil pack for my 2wd cosworth and were would u mount it and what leads do u use. i wont to run omex
thanks
Old Feb 18, 2006 | 12:03 AM
rapidcossie's Avatar
rapidcossie
i have coil packs on my saf.
uses the zetec coils.
can take some pics if you want??
Old Feb 19, 2006 | 09:58 AM
BMEP's Avatar
BMEP
I’m also running 4 separate coils threw my Autronic. I mounted the battery in the boot and mounted the Autronic CDI and four coils were the battery use to be
Old Feb 19, 2006 | 12:14 PM
2litresi's Avatar
2litresi
could u send me one thanks
Old Feb 19, 2006 | 01:11 PM
rapidcossie
will have the up in half and hour mate
Old Feb 19, 2006 | 02:05 PM
rapidcossie
amplifer
zetec coil pack on custom bracket
Old Feb 19, 2006 | 09:03 PM
2litresi's Avatar
2litresi
What leads do u use
Old Feb 20, 2006 | 05:54 PM
rapidcossie
standard ford ones converted for the coil packs
Old Feb 22, 2006 | 09:51 PM
2litresi's Avatar
2litresi
thanks
Old Feb 24, 2006 | 12:25 AM
devilac's Avatar
devilac
to make this conversion you didn't have to change the ECU just plug and play after taking the dizzy out ?
Old Feb 24, 2006 | 06:28 PM
rapidcossie
my car runs an SM4 autronic ecu but think it can be done on any ecu with a bit of modifiying??
Old Feb 24, 2006 | 07:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
to drive the coil pack, you need 2 trigger signals. to generate those, you need the crank position and phase sensor signals, which go to the ecu. std cossie ecu's will not do it without modification, but many aftermarket ones do it as standard.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
A.t.p
Sep 29, 2015 05:04 PM
