front bumper
Old Feb 17, 2006 | 11:56 AM
statto's Avatar
statto
Default front bumper
my front bumper is sitting out a bit from the left side light, more so than the right side.
could this be a broken mounting or some dodgy fitting work
Old Feb 18, 2006 | 06:16 PM
Simon Day's Avatar
Simon Day
Check both the retainers are fitted either side, you will probably find that one is missing.
Old Feb 19, 2006 | 08:48 PM
stookay's Avatar
stookay
Default re bumper
as simon says there are two black plastic pins which clip into a vee shaped mounting , these can come loose , they situated inside bumber on the sides , mines was loose when i got my car got local coach works to re align it for a few quid, but am sure you could do it yourself .
regards stookay
Old Feb 20, 2006 | 08:16 AM
statto's Avatar
statto
do they just push in or what way are the clips fitted
Old Feb 20, 2006 | 11:49 AM
Rippers's Avatar
Rippers
Monte Geek
I bought a set today as I had one missing:-
Old Feb 20, 2006 | 09:51 PM
Rippers's Avatar
Rippers
Monte Geek
Actually just fitted the round twisty thing with the arrow. But whats the other bit for? Thought I'd work it out but I haven't a clue
Old Feb 20, 2006 | 10:10 PM
cos jon's Avatar
cos jon
Each end of the bumper has two fixings,
The top bumper fixings (top two in pic) locate in a sort of plastic slot that is fixed to the bodywork just at the leading edge of the wheelarch,
The other twist fittings (bottom two in pic) help secure the bottom edges of the bumper to the bodywork from inside the wheelarch (Push in and twist 45 deg)
hope that helps ......
Old Feb 20, 2006 | 10:25 PM
THE RADMAN's Avatar
THE RADMAN
As jon says,ive got some pics but photo*uckit isnt playing at the mo
Old Feb 20, 2006 | 10:28 PM
Rippers's Avatar
Rippers
Monte Geek
If you could sort a pic Radman I'll be greatful as I'm still not getting it do you know the part number so I can look it up on microcat to get the pic?
Old Feb 21, 2006 | 06:33 AM
THE RADMAN's Avatar
THE RADMAN
TOP bumper lug slides into top cup,lower twist in fixing goes through lower hole and into bumper
Old Feb 21, 2006 | 08:13 AM
Rippers's Avatar
Rippers
Monte Geek
Old Feb 21, 2006 | 12:19 PM
statto's Avatar
statto
yeha, looked at her the night and it the twisty bit thats missing, can these fixings be got from ford and what sort of Ł are they
for the help lads, just need the water leek sorted and we good for the summer
Old Feb 21, 2006 | 12:22 PM
Rippers's Avatar
Rippers
Monte Geek
Got mine off ebay mate as I couldn't find them on microcat
Old Feb 21, 2006 | 03:42 PM
THE RADMAN's Avatar
THE RADMAN
theyre only pennies mate,just hope its only the twist in part thats missing and that the part it fixes to isnt broken
Old Feb 22, 2006 | 12:11 PM
Tandy's Avatar
Tandy
saw some of the plastic fittings on ebay if thats any help
Old Feb 23, 2006 | 11:36 AM
statto's Avatar
statto
aye the plate they fit to is in perfect order, just the wee twisty thing that is missing, thanks lads
Old Feb 24, 2006 | 11:50 AM
salmon's Avatar
salmon
How do you go about taking the front bumper off? Bought the clips just need to bother my ar$e to fit them!
Old Feb 24, 2006 | 04:59 PM
THE RADMAN's Avatar
THE RADMAN
remove clips, fogs and indicators,then under the bumper and behind it are 4 bolts 2 in each chassis leg,front ones need to be removed back ones just loosened,then it pulls off,dont forget to disconnect the h/lamp washer hose at the bottle end from under bumper, do not remove the torx headed adjusters from below the number plate area,these are not designed to be removed as they are for height adjustment only
Old Feb 24, 2006 | 07:58 PM
Speedy G.'s Avatar
Speedy G.
Originally Posted by THE RADMAN
remove clips, fogs and indicators,then under the bumper and behind it are 4 bolts 2 in each chassis leg,front ones need to be removed back ones just loosened,then it pulls off,dont forget to disconnect the h/lamp washer hose at the bottle end from under bumper, do not remove the allen headed aDJUSTERS from below the number plate area,these are not designed to be removed as they are for height adjustment only
Nick,
I always remove those as that's LOADS easier.
Old Feb 24, 2006 | 08:24 PM
THE RADMAN's Avatar
THE RADMAN
problem is geert,they have a weld on the end to stop them coming out,so it either snaps off if your lucky,or strips the threads in the process then its a pain of a job drilling out holes etc to get another bolt to fit , as [yes youve guessed it] this is a special bolt which isnt available separately
Old Feb 24, 2006 | 08:28 PM
Speedy G.'s Avatar
Speedy G.
Mine then snapped off but I've had replaced bolts made up at a local place because the head was worn out.
Now, where are those 4 bolts you are talking about?
Are these as easily reachable as those 2 I'm talking about?
Pictures would be nice.
Old Feb 24, 2006 | 08:30 PM
THE RADMAN's Avatar
THE RADMAN
no,not as easy mate,next time you remove bumper just look at the other end of the brackets that you removed your bolts from
Old Feb 24, 2006 | 08:36 PM
Speedy G.'s Avatar
Speedy G.
How the hell will I be able to see these m8.
Do you have ANY idea on how low my car is???
Old Feb 24, 2006 | 08:51 PM
THE RADMAN's Avatar
THE RADMAN
about as low as mine,lol,you can see em easy without bumper on
Old Feb 24, 2006 | 09:02 PM
Speedy G.'s Avatar
Speedy G.
Right, another task at hand AFTER the NBR.
Don't wanna risk not being able to drive up there without the front bumper.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
