L8 ECU to run closed loop/coil pack conversion
L8 Ecu with closed loop installed and coilpack conversion
Plus wiring harness for twin amps
2nd ignition amplifier
Genuine ford coilpack
HT leads with coilpack ends
Stainless steel lambda boss
Bosch lambda sensor.
All the above ready to install and all brand new from Stu @ MSD
£720 delivered.
Grab this while you can as i no Stu has a list of people as long as his arm waiting for this conversion.
I also have a brand new set of Siemens 83lbph injectors brand new £250ovno delivered
1 no Air to Air injector Invertor board new £45 delivered.
1 wide band commander.Air fuel Ratio monitor brand new and unopened
£300 delivered.
I will add to the list as i sort more parts out.
£720 delivered.
£300 delivered.
PassionFords Creator
Blimey Paul, these bits are a tad cheap
I can confirm ALL these items are brand new as described by Paul as i supplied them ALL.
Sorry you have to sell it all pal, i really am.
Hi Dave
paul just wanted the coil packs mate as he was not going closed loop yet so i needed to sell as a complete kit mate as things have gone bad here so everything must go
Its all booked in for Closed Loop on Saturday.
Hi Dave
Paul just wanted the coil packs mate as he was not going closed loop yet so i needed to sell as a complete kit mate as things have gone bad here so everything must go
thought you was not going closed loop Paul.
Ive said all along i was going Closed Loop Dave, im getting 200 miles to a tank.
whats wrong with that.
thats all i go off most times.
get the greys in first then go closed loop.
Im just gonna leave it on the greens Dave and get it good on juice for a change LOL.
I'll go coilpacks at alater date, if matt can get all the bits. I no Scotty has got the kits in, but no leads.
big_Rad
Sep 15, 2017 09:36 AM
