CAM BELT
All depends what cam belt tensioner you have, and if you have used a de-comp plate.
if you have used a 1.3 CVH tensioner, and NO de-comp plate, then a standard CVH cam belt for the turbo engine is fine.
If you have used a 1.6 CVH tensioner, or a decomp plate, then you will need a extra long one, Mad Fot It sell this cam belt.
but you must of used the CVH bottom pully as well, as the zetec one has more teeth so you wont ever be able to time it up.
hope that helps.
hope that helps.
Mc5506
Oct 5, 2015 09:57 PM
