Air bag Light
Old Feb 14, 2006 | 12:51 PM
escort cab's Avatar
escort cab
Default Air bag Light
My Air Bag Light flashes but not all the time some times it does and sometimes it doesnt.
Any one have any ideas, if some thing needs fixing fair enough but i thought it may be sensor or sumit
Old Feb 14, 2006 | 12:58 PM
EssexBoyRacer's Avatar
EssexBoyRacer
you need one of those diagnostics machines that can identify the error.
Most garages can do this for you but there is usually a charge just to plug it in and tell you whats wrong with it!
Old Feb 14, 2006 | 05:36 PM
mach's Avatar
mach
hi there mate, have you been tampering with your seat and maybe unplugget the seat belt pretensioner, without having the ground terminal of the battery?
try taking the ground connection of your battery and check those yellow plugs.. If the lamp lights up with the 4 blinks then off, then 4 blinks, then its probably the other yellow plugs (for side airbags as far as I remember) under your seats that needs some love, they can get some bad connections. So, again you need to take off the ground connection on your battery, and unplug-plug the plugs for 3 or 4 times, and then connect the ground connection to your battery and see if it stills does the blinking... if this does'nt do the trick you should take it to ford and let them trouble shoot on it, since it might be something serious!
The faulty plugs is pretty common, and as written above, pretty easy to fix
Old Feb 14, 2006 | 05:46 PM
escort cab's Avatar
escort cab
Default Cheers
Thanks it does flash 4 times then stops ....
I will have to have a bash at that on the weekend.
Old Feb 14, 2006 | 07:03 PM
mach's Avatar
mach
yup, easy as scratching yourself :-D if you got any of that silicone electrical grease stuff (I have no clue on what to call it in english, other then that ) then put a little on the connections in the plug, to prevent future corruption in the plugs
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
