Group A rear beam
Are they worth the cash, have heard plenty of good things but as they are very pricey I wanted some more opinions first-pref from people who have got them or been in a car with one fitted
Originally Posted by madevelopments
I have used the Ahmed 1 IMO it is the best out there by far def worth the extra.
Mark
Mark
have you managed to find your farm yet
Thanks Mike,
Not particularly clear from the big picture, looks like its only rose jointed/adjustable on the inner mounts?. Surely this is limiting its adjustability (camber only). With the Zoo the outer is also rosejointed and adjustable allowing toe to be dialed in too.
Paul.
Paul.
As I said, there are ,many versions of the beams depending on what you want to be adjusted. The Ahmed one in the picture was the basic one (Ł850) with only the camber being adjustable
As you correctly point out the Ahmed one uses vastly superior rose-joints, however, I pointed this out to Brom and he now supplies the mega rose joints as a cost option
Do you have the pukka joints fitted to your beam Mike?. I only ask because I have to lubricate mine every so often to prevent squeaking(I don't have the johnnys over them either )
Paul.
Paul.
I've heard rumours regarding the rose joints on Zoo rear beams becoming loose................. People are having to get them tightened & re adjusted from thier own pocket.
Anbody confirm that?
its a lot of money just to get the best from the rear beam.
rather go sideways around the bend.
well.....most times.
The standard rear set up causes the car to understeer, as their is huge difference in roll centres / bump steer, so the standard rear actually makes the front push on (which if you study your crash footage, you can see this in action
).The Grp A beams even up this disparity, which makes the car more neutral.
Franco,
This happened once on my car when the beam was first fitted, and Zoo paid for a full realignment and set up at my local alignment centre. I have not had any issues since.
Jakob,
As Paul says, the "strapped" version with motorsport rose joints would be essential in your pot-holed country
Jakob,
. At present, this precludes the Bayjoo item, as it is not strengthened.
I must sort it out sooner or later. I will probably be boring you to death with questions at the Ring
Why would you? Or are you just stating that that is the kind of impatient person you are?
I had two passengers in the car and bearing in mind one of them was 2 (so cot, push chair etc), it should fit in your car, as it will be in three pieces...
I'm going to have 2 people in the car too. But maybe it could be done.
You know how much gold I have to rob from the bank?
You have to decide on the version you want first
We then need to drag Brom away from his Bromettes and make sure he can do one in time
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
