does r&d quickshift replace the linkage?
Old Feb 13, 2006 | 11:08 PM
zippyobrien's Avatar
zippyobrien
Default does r&d quickshift replace the linkage?
when using a rally design quick shif, will this replace my linkage.
also will it replace the bushes as my gear change is shockingly bad, its got to the point were only first and fith are the only easily selectable gears.
i want to no if the r&d kit will make it fell tight again (obviosly not as good as a bm, but even a new standard linkage would be good)
does it replace the rubber parts with metal as in the b&m kit?
will fitting one sort my shonky change?
cheeRS in advance lads
Old Feb 13, 2006 | 11:16 PM
DannyDK's Avatar
DannyDK
The rubber part with metal is not replaced in the kit i just got, havent fittet it yet though. The bushes are not included either, but i think they cost next to nothing at Ford
Old Feb 13, 2006 | 11:28 PM
zippyobrien
not available any more.
som one said fitting it to a worn out linkage would make it good again
Old Feb 14, 2006 | 12:44 AM
DannyDK's Avatar
DannyDK
you can get the bushes i Denamrk i was told at Ford in Ringsted(Danish Town)
Old Feb 14, 2006 | 12:57 AM
NUTS RuS's Avatar
NUTS RuS
The technical term I looking for is BOLLOX
Old Feb 14, 2006 | 01:18 AM
Tombra's Avatar
Tombra
Get a B&M shortshift!
You wil never look back
Old Feb 14, 2006 | 11:05 AM
zippyobrien
i was gunna go for the b&m but its 185. the rd ones is 50, so it means i can have one on both of my rs turbos
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
