what colour plugs go were help under throttle body
Old Feb 13, 2006 | 10:34 PM
ford crazy's Avatar
ford crazy
Default what colour plugs go were help under throttle body
cant work out what plug goes where under throttle body inlet manifold
there are four plugs black blue yellow and brown
can some one please put me right
thanks
Old Feb 13, 2006 | 11:02 PM
zippyobrien's Avatar
zippyobrien
blue is cold start valve, goes on the red banjo on the centre bottom. id leave the blue disconnected tho for better cold starting
Old Feb 14, 2006 | 06:01 AM
HORNETS7's Avatar
HORNETS7
blue cold start
black auxillary air device
yellow thermo time swithc
beige temp sensor
Old Feb 14, 2006 | 08:30 AM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by HORNETS7
blue cold start
beige temp sensor
Bottom 2 are the wrong way round pal. Yellow is CTS.
Old Feb 15, 2006 | 12:52 PM
ivorbiggun's Avatar
ivorbiggun
All the plugs and sockets are colour coded with the exception of the cold start (blue plug) which socket is as stated above below the plenum with the banjo connector/follow the fuel line from the metering unit. The yellow plug connects to the yellow socket , black to black + brown to brown. Vary hard to get it wrong. Good luck.
Old Feb 15, 2006 | 05:18 PM
SafeChav's Avatar
SafeChav
blue cold start
beige temp sensor
i agree
Some are colour coded, if not its usually grey though.
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Brickhouse
Sep 21, 2015 11:00 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
