Air to air injector.
New and unused. Comes with new (correct) injector, manifolds, bracket and a loom with resistorwhich will plug directly into a Cosworth loom.
You will need either a Pectel baord or a Motorsport Developments controler.
£250 plus £7 postage.
Every component in the picture is new and unused. The injector has the correct flow rate and is NOT a fluid injector like some people try and use (the fluid is used to cool the coil of the injector and they can overheat if used as an air to air injector). This can be fitted along with an Motorsport Developments controler or Pectel board and then mapped into the ECU
Originally Posted by DazC
Hopefully Paul. I have the all the bits I need, just no time to make it up!!
I'll see if I can make it up tomorrow evening.
Originally Posted by Ad4m RST
hopefully have a set off you mate...still got one?
where about are you?
cheers
cheers
No problem Paul. Looks like I will be on it tomorrow morning anyway!
Originally Posted by Mark_1
what do the air to air injector do?
What Are Air Injectors?
Air injectors, are, as they sound, a set of injectors that inject air instead of fuel. They are commonly used to control the boost pressure output by a turbocharger.
There are many types available nowadays, including ones that only run a single injector.
How do they work?
The air injectors have an input to the top of them from the turbocharger and an output on the bottom to the wastegate. The injectors are wired to the ecu so they can be controlled.
The ecu air injector map is mapped against boost, rpm and air temperature. The injectors initially stay closed, keeping the wastegate closed too, encouraging the turbo to spin to speed as fast as possible. When the desired turbocharger pressure is aquired during mapping, the injectors are pulsed so that they open at that point, allowing air to flow to the wastegate. This of course opens the gate, bypassing some exhaust gas from the turbine wheel, slowing the compressor and leveling or dropping the boost pressure depending entirely of course on how much air we allow through. The beauty of this system is we can use a relatively weak actuator to achieve very large boost levels and we can accurately program boost curves into the system.
Any downsides?
Yes, if the injectors fail, due to the “Bleed On” configuration, the turbo will run whatever boost it can until something either stops it or something fails due to the fact we have blocked the pipe to the actuator.
How do they work?
Any downsides?
Any advantage to a stage 3 escos?
