Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
044 Fuel Pump fitting - a quick guide :)
Old Feb 13, 2006 | 04:14 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default 044 Fuel Pump fitting - a quick guide :)
After the rewire of my fuelpump wiring, it was deemed a relaible upgrade to fit an 044 "Group A" fuel pump
quick guide
Remove old manky fuel pump cradle
Assemble new pump and filter in a refurbished cradle
After struggleing and loosing about half a litre of fuel, it was decided to remove the pump from the cradle and put it onto the tank and refit the pump back into the cradle once connected to the tank
Bolt up new parts in old parts places remembering to use stainless nuts for ease of removal in the future
Route the brand new pump to filter line (this is assuming you have had one made) and tighten the banjo fitting on the pump, and the elbow fitting on the filter
Neaten up wires with cable ties and if you desire, support the stainless braided fuel line
Before starting the car, prime the pump a few times by switching on and off the ignition, then start the car
Stand back and listen to a nice buzzing fuel pump
Old Feb 13, 2006 | 04:17 PM
Nice one gracey, im just about to pop one on mine, so the tip about connecting to the new pump before lifting up the cradle will no doubt be useful
Old Feb 13, 2006 | 04:18 PM
Graceland's Avatar
Graceland
Team HOTHOT!
and it will save you burtsting into flames too should there be any naked lights nearby
Old Feb 13, 2006 | 04:22 PM
CosKev3's Avatar
CosKev3
Nice job
Did you make up the braided pipe,if not where did you buy it m8?
Fitted 044 pump to mine,just got to tackle the wiring
My pump/filter are in a Merc cradle
Think that rust around where your spring sits on the chassis could do with looking at m8
Old Feb 13, 2006 | 04:25 PM
I wont be naked as im fitting it, and even if i was, im still not light
Old Feb 13, 2006 | 04:28 PM
john's Avatar
john
Mine will be getting fitted this week also
Old Feb 13, 2006 | 04:33 PM
rsnissan's Avatar
rsnissan
sorted mine out yesterday too
Old Feb 13, 2006 | 04:41 PM
RichardPON's Avatar
RichardPON
Andy - tut tut.
Proper -10 fitting on the pump end please
Old Feb 13, 2006 | 04:42 PM
Graceland's Avatar
Graceland
Team HOTHOT!
got the braided from Huddersfield Hydraulics - took my cradle, pump and filter down, told him what i wanted and came away Ł20 lighter with a nice hose
the rust on the springcups isn't anything serious - i've looked at it when i was under the car and its solid underthere still
Old Feb 13, 2006 | 04:43 PM
Andreas's Avatar
Andreas
Seems like the Scandianvian climate is a bit more forgiving when it comes to rusting.
Here's mine, never bothered painting it.
Graceland, you could be mistaken for IMA with that "set yourself on fire DIY-style".
Old Feb 13, 2006 | 05:33 PM
rsnissan's Avatar
rsnissan
Andy - tut tut.
fitting it to the tank end was doing my nut in so gave up in the end and couldn't be arsed to weld a -10 to the tank
Old Feb 13, 2006 | 06:34 PM
Sticky.'s Avatar
Sticky.
I did mine last year, the day before Central day. Boy did the car overfuel that day
Big thanks to Lee R21 for sorting the pump out & the Aeroquip fitting kit
Nice mint Cradle that came off the car , all greased up
One nice 044 pump ready for fitted
Old Feb 13, 2006 | 06:36 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Originally Posted by rsnissan
Andy - tut tut.
I told you what to do.....you ignored me as usual!!!!
Old Feb 13, 2006 | 06:45 PM
CosKev3's Avatar
CosKev3
Hose looks good,can't go wrong for Ł20
Keep a close eye on the rust,thats the main area of rot which brings so many saph's to be broken for parts
Old Feb 13, 2006 | 07:30 PM
stu21t's Avatar
stu21t
gunna sound silly but, does it matter where you fit the pump and filter?
i wanna fit mine vertically and above the tank.
ive got a bracket from lee at fusion where the filter and pump bolt up next to each other but the best place for me to fit it is vertically above the tank, is this ok? i guess the pump will suck the petrol out and isnt gravity fed??
Old Feb 13, 2006 | 07:45 PM
CosKev3's Avatar
CosKev3
Pretty sure cosworth fuel pump IS gravity fed m8
Old Feb 13, 2006 | 07:54 PM
KSA-Cossie's Avatar
KSA-Cossie
Whats the benefit of the 044 pump over the standard one , is it higher pressure or flow ?
Old Feb 13, 2006 | 07:55 PM
stu21t's Avatar
stu21t
so i gotta fit it below the tank
Old Feb 13, 2006 | 08:02 PM
RST's Avatar
RST
sorry if you dont mind me buttin in lol ....
wat is the part number for a Group A fuel pump
Cheers RST
Old Feb 13, 2006 | 09:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Anyone ???
Old Feb 13, 2006 | 09:27 PM
twitchyrear's Avatar
twitchyrear
flows more fuel per minute than the standard one
Old Feb 13, 2006 | 09:29 PM
Anyone ???
Its capable of maintaining a higher flow rate at any given pressure.
On big BHP engines, the standard pump wont cope and you will run lean and melt someone.
Old Feb 13, 2006 | 09:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Many thanks gents !!
Old Feb 13, 2006 | 10:50 PM
Stu @ M Developments's Avatar
PassionFords Creator
Nice work Gracington
Sticky... putting a bigger pump on cannot make your car overfuel as the pressure regulator will maintain the same pressure at the injectors.
Old Feb 13, 2006 | 10:54 PM
stu21t's Avatar
stu21t
can any1 else conform that i can/cant fit the pump above the tank?
Well it could if your car had been setup on a pump that wasnt up to the job and was losing pressure during long injector duty cycles surely?
Old Feb 13, 2006 | 10:55 PM
Only if you use a lift pump and swirl pot mate, an 044 needs to be gravity fed.
Old Feb 13, 2006 | 10:57 PM
stu21t's Avatar
stu21t
i was thinking of running a swirl pot but i was told that as i have a 'D' shaped tank filled with foam that i dont need one.
and i dunno if i have enough space for one
Old Feb 13, 2006 | 10:58 PM
bud-weis's Avatar
bud-weis
Football Cwazy
have to be pretty fooked to do that i'd have thought, the pump just supplies a constant flow, the regulator decides what the injectors see doesn't it?
only would be a problem if the pump loses voltage under load i reckon ??
Old Feb 13, 2006 | 11:00 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
no you can't.
Old Feb 13, 2006 | 11:03 PM
have to be pretty fooked to do that i'd have thought, the pump just supplies a constant flow, the reg decides what the injectors get doesn't it?
The flow that pump provides is inversely and non linearly proportional to the amount of resistance present in the system
Old Feb 13, 2006 | 11:13 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah but an injector will only supply an amount of fuel dependant upon injector open time and the pressure within the rail, which is controlled by the reg, so if the car runs fine on standard pump with reg set to 3.0bar, then it will run the same with no adjustments to the regulator but with 044 pump ??
Old Feb 13, 2006 | 11:17 PM
SPADGE's Avatar
SPADGE
I give that cradle 1 week before its rusty as fook again lol
Whenever i change pumps i always do it with low fuel in the tank and then drain whats left 1st or just bung a spare piece of pipe with a bung in it onto the tank.
Old Feb 13, 2006 | 11:23 PM
Not if due to the amount of petrol leaking out of the system via the injectors being open the fuel pressure is acutally dropping slightly lower than 3.0 bar becaues you have maxed out the flow on the pump, therefore when mapping it you end up with the injectors needing to be open longer to get the same amount of fuel in.
Then you fit the new pump which now maintains the pressure like the old one should have done and bingo you end up running richer.
Pretty unlikely set of circumstances really, but just saying its possible, the regulator doesnt have complete control over the pressure, as all it can do is limit the fuel returned, if the pump flow has been used by the injectors, there is no fuel to return anyway!
Old Feb 13, 2006 | 11:25 PM
That was my actual point.
If the car had a decent chip, it would run lean if teh pump started to lean her off. When you then fix the problem theres no way it would run rich, it would just run right again, unless someone had actually mapped AROUND a failing fuel pump, which is bloody unlikely obviously.
Old Feb 13, 2006 | 11:28 PM
If the car had a decent chip, it would run lean if the pump started to lean her off. When you then fix the problem theres no way it would run rich, it would just run right again, unless someone had actually mapped AROUND a failing fuel pump, which is bloody unlikely obviously.
Stu, you of all people should realise to NEVER underestimate the power of human stupidity
Old Feb 13, 2006 | 11:37 PM
zippyobrien's Avatar
zippyobrien
will the o44 pump go on a series 2? rs turbo?
Old Feb 13, 2006 | 11:38 PM
It will go on anything with a fuel tank providing its gravity fed and installed correctly and you have an appropriate regulator etc.
Old Feb 13, 2006 | 11:40 PM
zippyobrien
sweet, cheers dude
Old Feb 14, 2006 | 07:43 AM
Graceland's Avatar
Graceland
Team HOTHOT!
this was my mistake - half a tank of optimax, now one litre less
