puma bearing gone tits
ello, need some technical help. me sister has a puma and it needs a rear wheel bearing replaced. can anyone tell me how i would go about doing this as i have no workshop manaul. do i need a tool to remove the bearing, also i suspect there are certain torque wrench settings which i do not have. any help would be great.
thanks.
thanks.
If you don't know what your doing should you really be doing it ?
I'd imagine its the same as most fords, wheel off, hub off, bearing off.
Bearing on, hub on and wheel back on
Welcome to Pf too by the way
Im sure someone will be along later to help out a little more technically
Im sure someone will be along later to help out a little more technically Thread
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
