Bouncing Rev counter
Hi all, i have a strange problem with my rev counter,
When i rev the engine in neutral, the rev counter works fine.
But when i drive the car, and put the pedal to the metal :P, the rev counter bounces up and down.
ive replaced all sorts of things of the ingnition, but with no result.
I even bought a seperate rev counter, tried it with new wiriring, but same thing happend.
Im al out of idea's now,
Greetz
Greetz
i had that problem sounds like the gearbox diff is moving and caused the rev to go up and down . gearbox i think rubes against the rev cables
that what happened on mine....
Rev cables?
The rev counter feed comes from a green wire located on the ignition coil. if you've already tried replacing the rev counter with no luck then the problem must be within that green wire. Check for any damage, could be a break in the wire from old age possibly.
Originally Posted by EssexBoyRacer
Rev cables?
So i think the problem has something to do with the ignition itself.
Because sometimes it seems, when the counter goes crazy, the power output of the engine also goes up and down.
.i will try another ignition, and if that won't fix the problem, im going to replace all the wiriring what has something to do with the ingnition.
Greetz
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
