Converting to a Turbo
Old Feb 12, 2006 | 10:18 PM
m-dtech's Avatar
m-dtech
Default Converting to a Turbo
I have a 1989 xr3i engine, how hard is it to convert ti RS Turbo spec ?
Old Feb 13, 2006 | 08:02 AM
HORNETS7's Avatar
HORNETS7
u will need a turbo engine,loom, radiator, intercooler ,metering head ,exhaust and if u want a lsd gearbox!
your talking
engine 200
loom 50
rad 50+
intercooler 20
metering head 50
zaust 80-100
gearbox 100-150
Old Feb 13, 2006 | 03:29 PM
Ben26's Avatar
Ben26
just buy a rs turbo mate .
then it will be Swings and roundabouts
Ben
Old Feb 13, 2006 | 05:19 PM
m-dtech's Avatar
m-dtech
i just thought that the existing engine could have been turboed but obviously not.
Old Feb 13, 2006 | 07:28 PM
G60's Avatar
G60
You can turbo your engine. But it depends to what extent for what you will need to do.
I think you can run around 7 or 8psi on the standard engine so you will just need a turbo,manifold for the turbo. A lot of re-wiring and get the fueling sorted. Possibley new injectors.
If you wanted to run more boost than that you would need a low comp rebuild.
Speak to van Haken or fiesta frenzy.
Old Feb 16, 2006 | 12:36 AM
rs_escortturbo's Avatar
rs_escortturbo
I was thinking of doing the same with my xr3i,i have the turbo,exhaust and intercooler,would it run any sort of boost by just fitting the turbo to it
Old Mar 10, 2006 | 09:26 PM
oiled's Avatar
oiled
i would fit the whole system from a good rs turbo you heard running. its not to hard a job but you need to make sure you have all the parts so maybe buy a full car crashed and swap over .
Old Mar 12, 2006 | 07:12 PM
paconassa's Avatar
paconassa
you can run around 7 or 8psi on the standard engine (ford sold a kit like that for the std XR3 many years ago, before the s1 appeared...) but watch out for ignition advance and fueling after the conversion...
good luck!
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
