a f r on w.o.t on turbocharged engine
Old Feb 12, 2006 | 10:18 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default a f r on w.o.t on turbocharged engine
what a/f/r/ should i run w.o.t on boost
i was thinking around 11 ish
1800 zetec turbo
4-7psi boost
Old Feb 13, 2006 | 07:25 AM
fredy's Avatar
fredy
too much i would be at 13-12.7 but use a EGT gauge and wach the temps up to 800c top at that boost
Old Feb 13, 2006 | 07:32 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
but i thought 12.5 was for n/a at w.o.t shurley i have to run bit richer on boost???????
Old Feb 13, 2006 | 05:22 PM
fredy's Avatar
fredy
no 12.5 is the best power eithr turbo and n/a
there is no frmula for that you should give you engine what he asks for beginig start rich and the lean it till the knok's but ther are more parameters to play with like ignition but all depends on your set up C.R 8v or 16v ect.....
my strong advice BE carful and use an egt gauge to!!! sart mapping from ninimal boost to max with steps no more tan 4-5 psi each time
Old Feb 13, 2006 | 05:26 PM
low 12s would make a good guess on that given how little boost its running IMHO (you mention 4-7psi), but as above you need to try it and see what EGT's do.
Old Feb 14, 2006 | 09:18 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
can i by a egt gauge how much do they cost?? in my ecu in the code it has a gauge for egt what do u use as a probe?? what out put dose it have ?????
i take it it just acts like ect sensor but messure exhaust gasses?
thanks alot for input guys
ps i am running 11.5 a/f/r at the min just working on spk advance table then i will start to lean it off then when nocks retard timing about 5 deg dose this sound like proper way to go??
thanks alot guys
tommy
Old Feb 14, 2006 | 09:21 AM
Sounds fine to me, although 5 degrees sounds very cautious, 3 should be nice and safe.
Is it megasquirt then?
Old Feb 14, 2006 | 10:00 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
how did u know that
sure is dose that sound about right
Old Feb 14, 2006 | 10:01 AM
Cant think of any other ECU you would have access to the source code for
Yes, all sounds fine mate
Old Feb 14, 2006 | 10:05 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
what about egt sensor probe what is it any cars come with it that i could robb it of???
thanks for help mate
Old Feb 14, 2006 | 10:08 AM
Some hondas have them, but trouble is you would need to calibrate it obviously against some known temperatures to know what voltage meant what to make any sense of it.
I personally would just buy an aftermarket gauge and sender calibrated to work together.
Old Feb 14, 2006 | 10:13 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
ok thanks alot mate will look into getting 1 got 3 spare bottom ends any how so this is a pure test engine if it dosent melt all the better
thanks again
tommy
Old Feb 14, 2006 | 10:26 AM
Cool get winding that boost up too then once you have it mapped
robbo9006
11
Sep 1, 2015 02:10 PM
