330mm AP 4 pot kit on a "MONTE"POSSIBLE??
Old Jul 23, 2004 | 11:24 AM
jon foz's Avatar
jon foz
Default 330mm AP 4 pot kit on a "MONTE"POSSIBLE??
anyone had any experience fitting these brakes under monte rims,if not 330mm,what did you end up with?
cheers
jon
Old Jul 23, 2004 | 11:52 AM
DaveEscos's Avatar
DaveEscos
no chance
i believe damo v has 310mm with AP 4 pots on his monte
calipers fit fine, just the disc size as its only a 16" rim
no point worrying about disc size on a monte anyway as you cant see shit from the spokes
Old Jul 23, 2004 | 01:00 PM
Glenn5's Avatar
Glenn5
I believe tarox do a 6 pot front brake kit for std escos wheels but it aint cheap pjs price is£1170 and thats a 305mm disc but i think u need wheel spacers aswell 2 clear the caliper.
Old Aug 15, 2004 | 06:49 PM
Damo V's Avatar
Damo V
You will JUST get a 330 conversion (maybe not all manufacturers though ) under Monte rims, though you wont be able to balance the wheels, you could fit spacers
I have CP5200 calipers (AP) and AP 315mm discs.
HTH
Old Aug 20, 2004 | 10:58 AM
Fozy's Avatar
Fozy
All you need is some wheels like mine and you can get some 6 pots and not loose the monte charateristics
Old Aug 20, 2004 | 11:50 AM
Damo V's Avatar
Damo V
Bastid
Old Oct 26, 2004 | 02:10 PM
Andy RS1700T's Avatar
Andy RS1700T
Got some AP 4 pots, would suit dics size 310-330mm if thats any help. andrew@abcdrobinsonfreeserve.co.uk - tried these under some RS200 alloys, woud fit with 325mm discs, hope this helps
Old Oct 26, 2004 | 07:23 PM
c0ss1e9i6's Avatar
c0ss1e9i6
Franco
Just get 18" speedlines as well!!!!!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
