330mm AP 4 pot kit on a "MONTE"POSSIBLE??
anyone had any experience fitting these brakes under monte rims,if not 330mm,what did you end up with?
cheers
jon
cheers
jon
no chance
i believe damo v has 310mm with AP 4 pots on his monte
calipers fit fine, just the disc size as its only a 16" rim
no point worrying about disc size on a monte anyway as you cant see shit from the spokes
I believe tarox do a 6 pot front brake kit for std escos wheels but it aint cheap pjs price is£1170 and thats a 305mm disc but i think u need wheel spacers aswell 2 clear the caliper.
You will JUST get a 330 conversion (maybe not all manufacturers though ) under Monte rims, though you wont be able to balance the wheels, you could fit spacers
I have CP5200 calipers (AP) and AP 315mm discs.
HTH
HTH
Got some AP 4 pots, would suit dics size 310-330mm if thats any help. andrew@abcdrobinsonfreeserve.co.uk - tried these under some RS200 alloys, woud fit with 325mm discs, hope this helps
