Installing an aftermarkter REVcounter???
Old Feb 12, 2006 | 08:13 PM
dmcruley's Avatar
dmcruley
Default Installing an aftermarkter REVcounter???
Hi, which wire do i need in the engine room to connect to my aftermarkter rpm gauge (rev counter) ??? (the gauge needs a negative input)
It is a Ford Fiesta 1.6 turbo from 1991 ... thanks in advance!!!
Old Feb 13, 2006 | 12:50 PM
JesseT's Avatar
JesseT
Either the coil wire will work if you can choose "2 cylinders" in the gauge. If not, you can try the CTO "clean tach out" which is pin 11 from the EDIS unit. This works fine at least in my escort using the original S1 clocks.
Old Feb 13, 2006 | 03:26 PM
dmcruley's Avatar
dmcruley
okeej, i connected to the coil wire (one of the green ones, seems both work) but chosen "4 cylinders"... it worked but not as it seems, so will try to change this to 2 cylinders..... thanks mate
Old Feb 13, 2006 | 03:37 PM
dmcruley's Avatar
dmcruley
won't work... i can only set up for 4, 6 or 3 cylinders
is it surely wire 11 (on the picture the arrow shows wire 10)
thanks
Old Feb 14, 2006 | 02:26 PM
JesseT's Avatar
JesseT
Pin 11 from the EDIS unit. That looks more like the instrument cluster connector or something.
Old Feb 15, 2006 | 04:23 PM
SafeChav's Avatar
SafeChav
Sorry to but in, but JesseT, on the FRST ECU is there a digital rev counter outputthat you know of? Preferably 5 volts, its for my HKS Turbo Timer
Old Feb 15, 2006 | 04:28 PM
JesseT's Avatar
JesseT
I have no idea of the ecu itself.
Old Feb 15, 2006 | 04:30 PM
SafeChav's Avatar
SafeChav
Oh ok it was worth asking though
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
