Harnesses?
Having removed my seatbelts completely now,i'm left with the holes where the belt used to come out of on the door pillar...any ideas of how to sort these out pls.
i have no pici, but i have them fitted, you remove the belt buckles behind the passenger and drives seat, then put the 'eye' for the harnesses in the wholes (one eye for each seat) then you put both of the rear parts of the harness in one eye. this means youll have two eyes, each with two bits of harness attached, then just push your lower rear bench back into possition
155lee
Oct 24, 2015 11:11 AM
SMILER258
Sep 28, 2015 09:04 AM
