Cossie problem
Old Feb 12, 2006 | 07:08 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Default Cossie problem
Hello,
Got a weird problem with my Saph Cossie 4x4.
It runs fine and then al of a sudden it runs very bad like it's getting not enough fuel,when i don't hit the gas it stalles,but when i keep the pedal on it runs not good.
It also sometimes happens when it idles,then it drops in revs and shuts down or revs again.
Any ideas??????
Old Feb 12, 2006 | 11:36 AM
Staffi's Avatar
Staffi
Could be the IDLE SPEED CONTROL VALVE...........
Old Feb 12, 2006 | 11:52 AM
SWIFTY's Avatar
SWIFTY
Default mine did the same
i clean out the idle control valve then all was fine with the world again. some people just disconect it
Old Feb 12, 2006 | 02:08 PM
vyper developments's Avatar
vyper developments
try adjusting the base idle on the bottom of the throttle body, you want to disconnect the iscv plug then set this to around 850 rpm. this should then prevent the engine stalling.
CheeRS, Mike.
Old Feb 12, 2006 | 03:54 PM
grunter's Avatar
grunter
had same problem with my 2wd would rev up to 4 mayb 5000 revs then drop down touch throtle and it'd be rite up again turned out to be water temp sensor at back of head weird
Old Feb 12, 2006 | 05:22 PM
MARCOSWORTH
Mine has the problem at 3000rpm when driving,and on idle speed.
Old Feb 12, 2006 | 07:01 PM
grunter's Avatar
grunter
gotta be worth a look dude all i did was bridge the switch to eliminate it i.e take the plug off the sensor and put a wire across the plug to make a circuit
Old Feb 12, 2006 | 07:02 PM
dazzle740's Avatar
dazzle740
hi there mate
i would clean the idle control valve first just undo the two small bolts and it should just pull out but will be tight use something like brake cleaning fluid if this fails to sort it try a new water temp sensor
Old Feb 13, 2006 | 03:14 PM
MARCOSWORTH
Idle control valve looked good,have to check the water temp sensor later,hope this is the one then
Old Feb 19, 2006 | 05:46 AM
MARCOSWORTH
Put another ECU in it,runs much better now,starts fine,only thing is it's a standard one.Now just checking the fuel pressure cos it was using also to much.
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
