mobil 1 oil???
Old Feb 11, 2006 | 08:53 PM
larks's Avatar
larks
Default mobil 1 oil???
just bought my first cossie witch has been run on mobil one is it ok? have heard stories before that it is to thin for older engines is this true or just a fairy tell?????
Old Feb 11, 2006 | 08:55 PM
twitchyrear's Avatar
twitchyrear
i use it with no probs
15w50 fully sinthetic
Old Feb 11, 2006 | 08:56 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Two types of Mobil One to look out for matey - I use as do many on here Mobil 1 Motorsport 15/50 Ideal for Cossies
Don't use normal 0/40 - that is like piss.
PM Matt at ML for best prices - normally Ł20 for 4 litres, or try Halfrauds and pay Ł37 for the same stuff
Si B's Avatar
Si B
oh, and pics or STFU
Old Feb 11, 2006 | 08:58 PM
larks's Avatar
larks
last owner gave me some with the car will go check what it is
Old Feb 11, 2006 | 09:00 PM
larks's Avatar
larks
we are all good its the right one 15/50
Old Feb 11, 2006 | 09:02 PM
Si B's Avatar
Si B
Good stuff
0/40 Mobil 1 is great on a brand new performance car, but it has no place near leaky Cossies!
Roll on tomorrow for Weston then
Simon
Old Feb 11, 2006 | 11:36 PM
Ginge !'s Avatar
Ginge !
just finding my feet
0-40 is actually not THAT bad as you all make out
i ran it on my cossie as a mate had a 205 litre drum of the stuff and it was fine,,,,,,,, when it got rattly a few tuners mentioned about it being the oil making it do that and to change to 15-50 and see the difference and so as i had a 7 litre sump i bought 75 quids worth to find,,,,,,,,,,,, wait for it
FOOK ALL DIFFERENCE !!!!!!
its a nicer oil and will shut up the tappets i supose but i remember that 10-40 caused the zetecs to have sticky valves and ford actually recomend -30 oil on cossies ect now
Old Feb 12, 2006 | 12:59 AM
Linsay's Avatar
Linsay
My old s2 engine did 176'181 miles and was still going using Mobil 1 i've always used the motorsport 15w50 with it
Old Feb 12, 2006 | 01:03 AM
Ginge !'s Avatar
Ginge !
how can you have,,,,,, it aint been about over 3 years has it
Old Feb 12, 2006 | 06:14 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
how much?
i wanna get me some of that! i take it you can post oil?
does matt post here much? i need oil for when i get onshore!
chop
Old Feb 12, 2006 | 11:18 PM
Si B's Avatar
Si B
how much?
chop
Matt doesn't post on here much which is a shame as he knows his cars and his prices are usually the best around. I've bought gallons of oil off him, as well as coil overs, and various genuine Ford engine parts at excellent prices.
He can post oil, but generally I see him at shows and pick up a few cans every few months.
His name is Matt Lewis - not sure what he posts under on here - either that name or Matt@ML rings a bell.
If you're stuck I'll try and find out his proper user name if I can
Simon
Old Feb 12, 2006 | 11:26 PM
EIL132's Avatar
EIL132
Yes you can, check the website
http://www.mobil.com/UK-English/Lube..._Super_XHP.asp
Old Feb 12, 2006 | 11:34 PM
buftyboy's Avatar
buftyboy
pm matt as he logs in at least once a day
username. matt lewis
Matt's Avatar
Matt
rattly is fine then
point proven
dont use 0-40 in a yb
mjonathan24
Oct 29, 2015 10:39 PM
