steering
Old Feb 11, 2006 | 05:44 PM
rssapphowner's Avatar
rssapphowner
Default steering
hi peeps this problem is driving me nuts on my 2wd cossie my steering is really light and if i get in ruts in the road it oes all over the place my tracking id fine i was wondering if it is the wheel bearings???? i am stumped any ideas peeps
Old Apr 10, 2008 | 04:47 PM
sideways saff's Avatar
sideways saff
this is exactly the same issue that i have at the moment.....i have changed steering rack,polly bushed it,changed shocks and springs,it is better but not right , hopefully some one else has had the same problem and can shed some light on this ??????
Cheers Matt
Old Apr 10, 2008 | 05:47 PM
iansoutham's Avatar
iansoutham
OCD Victim
Couple of questions for the pair of you:
a/ what size wheels and tyres do you have?
b/ you say the tracking is fine, but what are the measurements, tow in, toe out?
c/ is the steering rack central, i.e. exactly the same number of turns lock to lock from centre?
Reasons are because larger wheels and tyres can cause light-handling
If you have too much toe in, the steering will be very light and will not want to self-centralise, causing instability
If the steering rack is not central, then you will not be driving in the "dead-spot" where the power assistance is @ its minimum. This is a small area on the rack spline (internally) where the PAS pump does not run under pressure. IF the steering is off-centre, then the PAS will be working continuously (normally more noticable one way than the other) and the steering will feel light and twitchy.
Check the above and come back to me with the results and I will see what I can sort out....
Old Apr 11, 2008 | 11:02 AM
sideways saff
ok cool i am running escort cosworth wheels 8x16 , iwill check the lock to lock and also get the tracking checked again .........i'll then let you know the outcome
cheers
Matt
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
