ERST S2 MORETTE WIRING INFO
Old Feb 11, 2006 | 12:00 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
Default ERST S2 MORETTE WIRING INFO
HI THERE , IVE GOT MYSELF SOME NEW MORETTE HEAD LAMPS BUT I HAVENT GOT INSTRUCTIONS ON HOW TO FIT THEM.........IN THE BOX THERE WAS ONE SET OF WIRES BUT I HAVENT GOT A CLUE WHICH WIRES GO WHERE.............ANY CHANCE OF ANYONE HELPING ME OUT BY TELLING ME WHICH COLOUR WIRES/PLUGS GO WHERE........PICTURES WOULD BE EVEN BETTER. THANKS IN ADVANCE EVERYONE !!!!!.
CHEERS
DAVE
Old Feb 11, 2006 | 12:09 PM
kjc300's Avatar
kjc300
I just got some new ones for my esc cos, and I'd assume they will be roughly the same!!!
is there a relay on the left hand set (sat in the car)??
if so, this is for the main beam on the inner set of lights, basically there should be a set of wires (pos and neg) with a fuse holder on. This goes up the inner wing up to the battery, then there should be another single wire which goes across to the other headlight and connects to the main beam bulb connection from that there should be a brown wire with a ring on the end to be attached to earth(ground) on the car.
The other connections simply plug into the normal bulb connectors!!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Mc5506
Sep 29, 2015 09:06 AM
