IS MY TURBO FCUKED????!?
Old Feb 10, 2006 | 11:33 PM
COSSIE 1's Avatar
COSSIE 1
Default IS MY TURBO FCUKED????!?
Right ive come to the conclusion from the siren type whistling sound coming from the engine bay area that my turbo might be fcuked , here are my symptoms.... i took the turbo hoses off and checked the play in the shaft and found no ovious movement in an out but there was some movement up and down id say about 2-3mm ish but there are no signs of it catching on the housing, on boost there is no smoke and apart from this noise the car is perfect, the turbo spoils up at the right time with no noises apart from this fcuking whine.....does it sound like its fcuked?? if so how much roughly would it cost to recondition it, inc removal and refit??? cheers........i believe it to be a cossie 4x4 T3 its got the numbers A/R 42 on the housing???but it could be a standard/hybrid escort T3??, im running 16psi btw
Old Feb 11, 2006 | 09:01 AM
Jim Galbally's Avatar
Jim Galbally
2-3mm thats SHITLOADS of play
Old Feb 11, 2006 | 10:53 AM
matt p's Avatar
matt p
As above mate
Are you the lad that bought he white ZVH for 2k?
Give Jamsport a call on 01604 755529 very helpfull mate.
Old Feb 11, 2006 | 11:01 AM
bigad4x4's Avatar
bigad4x4
Sounds like worn bearings
Old Feb 11, 2006 | 11:29 AM
cossiegreg1's Avatar
cossiegreg1
mine was doin exactly the same as yours and im afraid it was fucked
Old Feb 11, 2006 | 07:14 PM
COSSIE 1's Avatar
COSSIE 1
ive been told to expect about 1mm of play up and down so basically no movement is this correct??, is it expensive to replace the bearings??
Old Feb 11, 2006 | 07:18 PM
Brasso's Avatar
Brasso
Does the noise sound like when you blow into the top of an empty bottle?
If so, one of my turbos died shortly after.
Old Feb 11, 2006 | 07:27 PM
COSSIE 1's Avatar
COSSIE 1
BRASSO..difficult to tell sounds vry much like a police siren but in a whistly way mate it does it on part throttle aswell???, starts to make the sound at about 2k but on full throttle at say 4-5k cant really hear it as much??????, any ideas on how much for a replacementset of bearings??
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
