what bhp ?
hello thinking of buying this what bhp do you think it might be running with the spec below.and does anybody know the car
Car details are as follows..... Ford escort rs turbo Selling with no reserve.
1650cc rebore using accuralite pistons and rings
performance big ends
high stress thrusts
Burton top and bottom end gasket set
H/d flywheel bolts
H/d big end bolts
Larger capacity mondeo zetec oil filter.
Kent alloy vernier pully
Kent cambelt
Kent cam with anti pump lifters
Ported and polished head to stage 2
Lightened and balanced bottom end
Lightened and balanced flywheel
Helix cermatallic paddle clutch
10" slimline Kenlowe fan
Cosworth fan switch
Alloy swirl pot
Uprated turbo grp n stage 2 with a/r 42 compressor and a/r 18 exhaust with 360 degree thrust bearing and oil feed
Heatwrap manifold
JR airfilter
DV 36 venturi baily dumpvalve
GRS motorsport twin pass evo 4 front mounted intercooler
17" wolfrace ikon alloys with 205/40/17 tyres
Lowering springs
EBC turbo grooved discs with dimples
EBC green stuff pads
Black diamond braided brake hoses and dot 5.1 fluid
Series 1 downpipe and stainless steel back bow with 4" slash cut pipe
Series 1 ECU running a collins motorsport chip and series 1 fueling computer
thanks
high stress thrusts
H/d flywheel bolts
H/d big end bolts
Kent cambelt
Cosworth fan switch
Alloy swirl pot
Heatwrap manifold
JR airfilter
Lowering springs
thanks
boost dependant 200brake!
Id want to know more about the Ecu. If you are serious I recomend you find out what colour's or shapes are on the ECU, wont take seconds to see.....it may be that its Stage 1 rather than Series 1 ECU.
Series 1 ECU in a Series 2 RST isnt a good Idea.
looks a nice car
looks a nice car
Some of the earlier ECU's didnt have a knocklink, where as the later 1's did. The car in pic being 90spec should have an ECU with symbols on it.
Im sure others will assist here but the 90spec ECU has
A (Heart shape) a (#) and another symbol on it.
hope that helps
hope that helps
Originally Posted by swerv
series 1 ECU is the best one , got one fitted in my series 2 , very good modification to make
Each to their own though
Yes we all have different ways of doing things, the ECU is only missing the knock sensor that is the problem with late ecu’s, and they always go wrong and make the car very sluggish!
The series1 ecu makes the car run smoother not necessarily quicker
Looks a nice car, for 4K it should be very clean, no previous welding, lowish miles, and a good service history and overall appearance should be very well. Ive saw almost (well not too far away from it) concours cars being sold for 4K! And ofcourse makesure the engine is what it sais!
The thing is with buying any modified car is always take the spec with a pinch of salt as it will turn out to be untrue or thrown together!!
Look at the whole car and see if the actual car is worth it, you’re buying a car not a spec list.
Check all history, rust is a major issue and there are no specific areas to check, check everywhere
If you move away from heavily modded ones like the one you have seen and start to look at cherished/show cars and then modify it yourself you will end with a much nicer car
Hope this helps
Hope this helps
lots of genuine modified cars are out there , not everyone tells porkys
Originally Posted by tubbykev
seen this car on ebay........but over priced if u ask me? Im running similar mods and im expectin about 200bhp ish.
Kiddie, its your old car with forged plates and a few subtle touches
There's better ways to aid air flow than that, but looks clean
Could always just get some new ecu's and go from there...
