play in propshaft centre bearing!!
Old Feb 10, 2006 | 01:45 PM
lammylama's Avatar
lammylama
Default play in propshaft centre bearing!!
ive got a bit of play in my propshaft centre bearing on my 2wd saff.Ive just called fords who said they dont sell the bearing or rubber donut on there own anymore so id have to buy a whole shaft...yeah right.,but ive phoned up another car spares place and they said it could be the bearing that has seized causing the rubber donut to wear out or could just be the rubber donut itself.Does this sound about right to you and what have you guys experienced in the past.
Old Feb 16, 2006 | 12:29 AM
cossy2wd's Avatar
cossy2wd
hi mate i had a center prop bearing go on my 2wd saph i phoned up fords they said they could not get one then they phoned me back & it was a bloke that nows all about cossies & he said he could get one he ordered it from fords in germany & it was only £60 ok mate (ford newbury 01635555340 ask for matty if this no has changed get them to put you through to newbury).
Old Feb 16, 2006 | 09:49 AM
arni's Avatar
arni
is there a difference between cossies centre bearing and other, weeker 2WD sierra/saff versions ?
can you upload a pic of your driveshaft ?
Old Feb 16, 2006 | 12:46 PM
lammylama's Avatar
lammylama
top stuff matey...will give them a try
Old Feb 16, 2006 | 02:40 PM
toff's Avatar
toff
a was going to post the same topic, a just got the same answer just before a logged on.
a better give them a call too
Old Feb 18, 2006 | 12:05 AM
rapidcossie's Avatar
rapidcossie
surely one of the breakers could help yous out?
Old Feb 22, 2006 | 11:22 PM
cossy2wd's Avatar
cossy2wd
let us no how you got on
Old Feb 23, 2006 | 12:30 PM
lammylama's Avatar
lammylama
yippee...phoned matt at fords in newbury and he gave me the finnis code for the centre bearing,i then called the same dealer local to me who told me i had to buy the whole shaft and guess what???...he can get one for the morning...
finnis code is 1613023
Old Feb 23, 2006 | 12:45 PM
rapidcossie
how did you know there was play in it?
what are the symptoms?
Old Feb 23, 2006 | 12:51 PM
lammylama's Avatar
lammylama
get it up on ramps and grap hold of the propshaft either side of the centre bearing and push it up and down...mine had a load of play in it and the rubber donut is being squashed out the side......when you pull away you will get a bit of a shudder and maybe a knock on gear changes.
Old Feb 23, 2006 | 04:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Glad you got it sorted bud.
Old Feb 26, 2006 | 11:41 PM
cossy2wd's Avatar
cossy2wd
sorted then mate i new you can get them still glad your happy now alan
Old Feb 27, 2006 | 04:43 PM
lammylama's Avatar
lammylama
thanks for the contact alan....i wouldnt have got it without you mate....cheers
Old Feb 28, 2006 | 11:21 PM
cossy2wd's Avatar
cossy2wd
no probs mate thats what were all hear for to keep em rolling
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
