disconnecting cable from clocks?
Old Feb 9, 2006 | 06:39 PM
thedaddie's Avatar
thedaddie
Default disconnecting cable from clocks?
how do you remove the cable from the back of the dash clocks?
cheeRS dave
Old Feb 9, 2006 | 09:01 PM
dave cos4x4's Avatar
dave cos4x4
Squeeze the plastic clip at the end of the speedo cable and pull.
squeeze the 2 straight bits on the plastic bit.
Old Feb 9, 2006 | 09:39 PM
jay man's Avatar
jay man
be carefull as its very tight at the back of the clocks there is not much room and you could pull the cable out the other end
Mark_
14
Jan 16, 2016 05:27 PM
muz
Sep 30, 2015 08:29 AM
Mr S1
20
Sep 27, 2015 04:06 PM
Flatlinedan
Sep 18, 2015 12:41 PM
