Cvh head worn near rockers help needed??? SORTED
Old Feb 9, 2006 | 08:13 AM
turbo.jon's Avatar
turbo.jon
Default Cvh head worn near rockers help needed??? SORTED
Well ive finally got round to changing my cam in car as it was worn on number 4 lobe and had destroyed a tappet which i replaced and worked fine for a while.but ive taken all lifters,cam and rockers off and it looks like the rockers have been rubbing on the head and worn bits off it away now this aint right its got the little black spacer plates fitted on the bit you slide rocker over before putting nut on. but why would it do this is it because the cam is worn??????? any ideas as dont want put back together and it do more damage
few pics of it but not to clear..
Where its yellow is where its worn
cheers
jon
Old Feb 9, 2006 | 04:41 PM
turbo.jon's Avatar
turbo.jon
bttt
Old Feb 9, 2006 | 08:27 PM
cos jon's Avatar
cos jon
That is an odd one mate, i take it the rocker arms were torqued down to ford spec ?, as it looks like they may have been tightened too much, although they usually pull the stud out when too tight.
Sounds daft but the studs don't move do they ?
Old Feb 12, 2006 | 10:06 AM
SafeChav's Avatar
SafeChav
turbo.jon: Not offensively but are you sure there is wear there, hard to see in the pics. Those bits are usually a bit of a funny angle. The rockers are usually free to float, but with all the pressure from the lifters they get pushed up onto the curved surface of the piece inside so they rock smoothly.
Have you tried taking a picture on your camera with the flash off? And using the macro function (picture of a flower)?
Old Feb 12, 2006 | 04:20 PM
turbo.jon's Avatar
turbo.jon
will take some better pics as there not to clear there deff is bits that have worn just does not look like it in picks
Old Feb 12, 2006 | 10:09 PM
sexr3i's Avatar
sexr3i
isn't it
probably oil starvation, anything in the cvh head is prone to wear if not fed with plenty of clean oil. design fault really, if they're not looked after then the poor cam lubrication and high valve spring loads encourage pretty rapid wear. but if you've had really bad cam wear then I'd say you've probably got a bit of an oil supply problem to the head.
Old Feb 13, 2006 | 07:41 PM
xr-stu's Avatar
xr-stu
never seen or heard of that happening before!
got any pics of the underneath of the rocker?
i could understand it if the spacer wasnt in, (the rectangular thing) but looks like its there in the pic....
Old Feb 15, 2006 | 04:43 PM
turbo.jon's Avatar
turbo.jon
Ive found what prob was i had this head fitted to my fresh built engine when it lost all oil pressure and was run for about 2 mins tapping which has lost all oil in tappets which made followers rub on the head.i found this out as i fit all new bits yesterday and with no oil in lifters it was slightly rubbing but once engine ran and oil got in lifters it was all fine
thanks again everyone
jon
Old Feb 18, 2006 | 03:41 PM
ivorbiggun's Avatar
ivorbiggun
An engine with no oil in developing problems?...who'd have thought it?
kosienutter
31
Aug 22, 2015 09:55 AM
shortie
Aug 19, 2015 01:01 AM
ajamesc
Aug 17, 2015 03:31 PM
col93saphcos
Aug 7, 2015 03:21 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
