coopers ring headgasket?
Old Jul 22, 2004 | 04:41 PM
Jon(m600)'s Avatar
Jon(m600)
Default coopers ring headgasket?
I think the one on my car is on its last legs(when hot it starts on 3 cylinders with a little bit of white smoke then after 5 seconds it clears)its only been on a year,so can i sack it off and get a wrc one or do i have to fit another coopers ring one.
Old Jul 22, 2004 | 04:49 PM
Deano's Avatar
Deano
Dont you have to keep using Coopers once youve had the Block modded to fit the rings ??????
Old Jul 22, 2004 | 04:55 PM
wimwerf's Avatar
wimwerf
indeed.
Old Jul 22, 2004 | 05:09 PM
Ian M500COS's Avatar
Ian M500COS
If you machine the 43 or so thou step off the block you can convert to WRC gasket but you will have to note the compression change accordingly & machine the pistons to suit. Did that on one of my old engines and it worked fine.
Old Jul 22, 2004 | 05:15 PM
Ima-Racing500's Avatar
Ima-Racing500
As Ian says...get them machined out if you use 7.2-1 pistons you get around 7.9-1 comp ratio.
Coppers are wank..LOL...i used a copy one and a genuine one on my old engine and both blew
Old Jul 22, 2004 | 05:22 PM
kjc300's Avatar
kjc300
Mines just gone too!!!!
Old Jul 22, 2004 | 05:52 PM
Milko Pete's Avatar
Milko Pete
Its getting complicated m8!
I tell ya m8, we shud av Skylines.
Old Jul 22, 2004 | 06:23 PM
Jon(m600)'s Avatar
Jon(m600)
Yeh m8 cossys starting to get on my tits,but i just take it up bypass to remind me why i bought it.
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
