Fuel pump relay location
Old Feb 9, 2006 | 05:49 AM
IMOL's Avatar
IMOL
Default Fuel pump relay location
Where is the fuel pump relay located ?
Old Feb 9, 2006 | 09:42 AM
Tandy's Avatar
Tandy
drop the fuse box down and you will see all the relays cant find my hand book at the mo i cant remember which one it is but someone will
Old Feb 9, 2006 | 09:53 AM
Tandy's Avatar
Tandy
found it R9 Brown
Old Feb 9, 2006 | 10:42 AM
IMOL's Avatar
IMOL
Thanks
Old Feb 9, 2006 | 06:26 PM
Damo V's Avatar
Damo V
IMOL
Are you running a std engine loom or aftermarket?
Pectel looms have their own standalone relays
Old Feb 10, 2006 | 08:16 AM
IMOL's Avatar
IMOL
Im running a pectel p8 weber marenetti .(pectel modded for 8 injectors)
R9 relay (brown) if removed it does kill the fuel pumps.
If its differt please let me know !!
Old Feb 10, 2006 | 06:53 PM
Damo V's Avatar
Damo V
yeah thats right, but as I said on other post I would fit a relay elsewhere, run direct feed to pumps, then use R9 to activate new relay
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
15
Oct 7, 2015 03:43 PM
JESX12
Sep 4, 2015 09:16 AM
