Torque vs. bhp
Old Feb 7, 2006 | 10:07 PM
DannyDK's Avatar
DannyDK
Default Torque vs. bhp
Is it worth loosing 10-12 bhp to gain 20-25 nm i torque? The torque and bhp will also peak some 200rpms sooner if i choose to loose bhp to gain the nm in torque. What would you do?
Old Feb 7, 2006 | 10:28 PM
Andy-R's Avatar
Andy-R
Danny it all depends on what charactaristics you want from your engine, how you want it to drive, and what you will be using it for.
What are you thinking of building or having built?
Old Feb 7, 2006 | 10:46 PM
DannyDK's Avatar
DannyDK
its realy simple, change the original filterbox with a kn cone filter. It sounds better, but thats not why i would do it. I want more torque in low rpms, its a long way to 3000rpms when youre in 4 gear driving at 1800rpms and floor the pedal, it takes to long imo to realy go, not like my old xr3i, and it even had a 258 piper cam in it, so you can see that it wouldnt be that quick in low revs but it was, maybe my turbo is dead or something
By the way if the turbo aint broke, would it help to get a -31 actuator, and what does that thing do ecxactly?
I drive with 14psi boost by the way
Old Feb 7, 2006 | 11:07 PM
mark-rst's Avatar
mark-rst
A few people have chopped the front of the std air box.. it gives a bit more of bhp and torque... There was a feature in PF about it i think...
Old Feb 7, 2006 | 11:16 PM
DannyDK's Avatar
DannyDK
Ok, that sounds like an even better idea to me, to gain both things would ofcourse be the best
Is it "just" the front of the box or should it be drilled also, and its the normal panel filter thats in the box right?
Old Feb 7, 2006 | 11:17 PM
Andy-R's Avatar
Andy-R
Danny Id agree with what Mark says above cut the front off your airbox (Just the top half though) so your filter is still efective.
14psi sounds fine on the actuator you have! No reall need to change!
DannyDK's Avatar
DannyDK
Anyone please answer the question about the actuator
Old Feb 7, 2006 | 11:23 PM
Andy-R's Avatar
Andy-R
The actuator is used to open and close the wastegate on your turbo, 14psi would normaly sugest that your actuator has been uprated from standard and may well be a -31 anyway.
Old Feb 7, 2006 | 11:25 PM
mark-rst's Avatar
mark-rst
-31 actuator allows you to run higher boost as the spring inside is stronger and takes more pressure from the turbo to move it.
As andy said std actuator should be fine for 14psi, i believe most people change them when running around 17psi...
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DavidK
Sep 27, 2015 02:55 PM
Marv888
Sep 26, 2015 03:44 PM
