turbo flow rate
Old Feb 6, 2006 | 07:32 PM
big_wig_074's Avatar
big_wig_074
Default turbo flow rate
82 lb/min,how much is this?a lot?
big_wig_074
or 109 lb/min?
Old Feb 6, 2006 | 07:34 PM
Mark Shead's Avatar
Mark Shead
Look at around 10hp per 1lb.
Mark
Old Feb 6, 2006 | 07:37 PM
big_wig_074
although i guess 14.5kg is a tad heavy for a turbo?
Old Feb 6, 2006 | 07:41 PM
big_wig_074
also,with regards to boost control,this particular item uses a magnetic sensor off the shaft,then when it senses overspeeding it restricts the INLET! would that work well?also runs its own sump!
Old Feb 6, 2006 | 07:44 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
820bhp
and 1090bhp
i dont think aeroplane turbos will fit a car very well mate
Old Feb 6, 2006 | 07:47 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Greig... What you found
big_wig_074
want to know the operating pressure?inlet pressure 14.2-17.5psi
compressor outlet pressure 81-135psi!
just got the notes here. the inlet is 10cm diameter with the housing being 20cm diameter! would it matter what gas was passed through it?as it usually carries refrigerant which may have a different density,so would that affect flow?would have thought so!
Old Feb 6, 2006 | 07:48 PM
big_wig_074
rad,theres 2 on a vc10 mate,1 on each wing
Old Feb 6, 2006 | 07:49 PM
Charlie Chalk
Unknown.
I know there is, Ive worked on them for 3 years
I cant see how you could get one to work, From what ive seen of them
Old Feb 6, 2006 | 07:50 PM
big_wig_074
eh?its a sodding turbo. what bit wouldnt work?3 years?pah,get some sand in your boots smally!
Old Feb 6, 2006 | 07:52 PM
Charlie Chalk
Unknown.
All i'll say is good luck
Get a pic of one....
Old Feb 6, 2006 | 08:03 PM
big_wig_074
phone picture taken of the diagram i have here,repeat,im JUST looking at this as i go through my room! out of interest i am asking these questions,nothing more!
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
