what happens if the cambelt is TOO tight?
Old Feb 6, 2006 | 07:25 PM
xr-stu's Avatar
xr-stu
Default what happens if the cambelt is TOO tight?
ive tightend mine purely by guesswork on my zetec and worried ive done it to tight. had a the previous tensioner fall appart on me on saturday (VERY lucky the belt never skipped!!!!) and its just struck me that it might be my own fault for over tighening the belt? think this would cause the tensioner to fail?
Old Feb 6, 2006 | 07:29 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Possibly, but you'd have to massively over tighten it!
Basically if with the index finger and thumb you can just about turn the belt 90 degrees its fine. So when you look down on it its normally - that way. You can turn it to I that way If its very tight it will make a noise when running. A sound like its rubbing on something.
Old Feb 6, 2006 | 07:32 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mine made a screetching noise when i over tightened it, but YES the tensioner will fail if its too tight.
as said, should turn 90 degrees with fingers
Old Feb 6, 2006 | 07:33 PM
L33 BYT's Avatar
L33 BYT
It can wear your cam bearings/journals.
Old Feb 6, 2006 | 07:37 PM
xr4x4rs's Avatar
xr4x4rs
id get it checked asap if your not to sure mate
as the tensioners are only made of plastic aswell and would end up not so lucky nxt time
Old Feb 6, 2006 | 07:40 PM
xr-stu's Avatar
xr-stu
i think it might be a little to tight then! will check it tomorow i think!
cheers dudes, thought so but wanted to ask 2nd opinions!!
Old Feb 6, 2006 | 08:02 PM
Graceland's Avatar
Graceland
Team HOTHOT!
also if overtightened, it can strip the teeth off the belt aswell, and you will only realise it has done it once you start the car
Old Feb 6, 2006 | 11:29 PM
I normally use the "90 degree twist" test as well.
Old Feb 7, 2006 | 07:31 AM
Yes matt, thats a perfectly valid point, its just something you get a feel for over the years really.
Old Feb 7, 2006 | 07:38 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
On the longest span of the belt obviously, not between the pulleys
Old Feb 7, 2006 | 08:42 AM
James's Avatar
James
doesn't the tensioner have a mark or anything to line up with like VW's do?
Old Feb 7, 2006 | 09:08 AM
I never trust those anyway, same goes for the "autotensioning" springs found on some engines.
Chas
Oct 5, 2015 07:13 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
locum8
Sep 14, 2015 08:45 PM
mrknifey
Aug 30, 2015 11:48 AM
Sjieter
Aug 5, 2015 09:47 PM
