2 wd cossie using loads of oil
Old Feb 6, 2006 | 06:59 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default 2 wd cossie using loads of oil
Only had the car about 3 weeks and have put about 3 ltrs of oil in it.(5w40) I know that they use oil but this takes the piss
when I give it a bit of stick it kicks out a fair bit of smoke
I think the valve stem seals want doing as on start up there is a bit of
blue smoke but it must be more than that
Any advice would be good
Thanks
Matt
Old Feb 6, 2006 | 08:40 PM
bigad4x4's Avatar
bigad4x4
Its a slippery subject on OIL here mat , simon at woodford always recomends Castrol RS 10-60 for a cos, peoples opinions vary matey. The smoke on boost could be down to worn piston rings or worn turbo bearings. Try the oil and see how you get on
Old Feb 6, 2006 | 08:49 PM
daz1968's Avatar
daz1968
If using a lot, I would just save up for a bit and do the lot, I have learned the hardway, as mine was burning oil from the top and bottom end, although it was running fine, so I did the head thinking it was guides, only to find only a small difference, have now ripped engine apart and am going for rebore and rings, I did find though that changing from synthetic to a valvoline 20/50 racing mineral oil reduced my consumption a lot, and its only Ł20 for 5 litres, so worked out a little cheaper.
Old Feb 6, 2006 | 11:52 PM
jon@work's Avatar
jon@work
As above, 5W40 is too thin - use a 10 or 15 grade. May still be engine/turbo wear, though.
Old Feb 7, 2006 | 10:52 AM
Dave McB's Avatar
Dave McB
i find 5/40 a lot better for when the car is cold (im up ere in arctic scotland tho)
used 10/40 but its a bit rattly on cold
Old Feb 7, 2006 | 12:05 PM
rapidcossie's Avatar
rapidcossie
rings
BRAM
Sep 8, 2015 07:11 AM
Thanasis
Sep 7, 2015 07:33 PM
hopper350
Sep 4, 2015 12:53 AM
