help with rear disc conversion pls
just need a bit of help who is the best person to get the brackets with bolts from ??? and who does extended hoses as well
i will be running cossie 2wd setup
thanks ian
thanks ian
just what i was gonna ask but i want to use either saff 2.0 dohc rears or scorpio ultims v6 ones
i know u need eith focuc or rs2K cable
whats the down side appart from the arse end locking up if its not set up right?
Originally Posted by ian r
u need
cossie calipers
mounting brackets
rs2000 handbrake cable
extended brake hoses
and of course discs
correct me if iam wrong
cossie calipers
mounting brackets
and of course discs
If you only need the brackets contact RichM (on here)
I got mine off him as I was being lazy and with the bolts etc they cost me about Ł33 if I remember.
I just made my own lines up as its a simple job to do...
His website
http://www.rsrich.force9.co.uk/zetec-turbo/Brakes.htm
His website
I got all my stuff from Burton Power, really easy to do as well, took me about 25min per side with no problems! Back end does get a bit light when braking round corners!!!
