pinstripe removal and electrical question...............
Old Feb 6, 2006 | 05:12 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default pinstripe removal and electrical question...............
I've just put a new door on the saff, after a whopping 13 months searching for one and it has a silver pinstripe sticker on it - whats the easiest way of removing this?
Also, i've today re-wired the alternator to battery using some rather chunky cable - 12mm diameter and gold plated terminals, and then re-terminaled all the connections to the battery as i was only seeing 12.9 volts at hot idle on the SECS monitor, now its seeing 13.1/13.2 which is an improvement, but would this suggest that the regulator is past its best in the alternator? or the battery is past its best too
Old Feb 6, 2006 | 05:14 PM
For the pinstripe ,use a hair dryer and warm it up, then it should peel straight off ,any stickey residue left remove with white spirit and then polish up
Old Feb 6, 2006 | 05:15 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Or use near boiling water, same effect.
Old Feb 6, 2006 | 05:17 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i had the hairdryer idea for the pinstripe - but can't see mother been too happy about using her appliances
Old Feb 6, 2006 | 05:20 PM
Wait till she is out
Old Feb 6, 2006 | 05:25 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i'll clean the oil off too before i put it back
Old Feb 6, 2006 | 05:26 PM
AlexF's Avatar
AlexF
change them both
Alex
Old Feb 6, 2006 | 05:29 PM
Rick's Avatar
Rick
13.1 idle is good. The alternator isn't upto speed yet, whats it like at 2000rpm?
Old Feb 6, 2006 | 05:30 PM
Graceland's Avatar
Graceland
Team HOTHOT!
its the same all thru the rev range Rick
Old Feb 6, 2006 | 05:31 PM
AlexF's Avatar
AlexF
it should be the same all the way up
Old Feb 6, 2006 | 07:36 PM
Neil S's Avatar
Neil S
Gracey, I'm in the process of rebuilding my alternator at the mo. I'll keep you posted if you like?
I was told that the alternator output should be 14.5V, not sure how true this is
I've got 13.2-13.4 at the ECU now, which is good as my battery voltage is about 13.4-13.5, but I'm looking for a bit more...
Neil.
Old Feb 6, 2006 | 07:41 PM
pee vee's Avatar
pee vee
I think the thread the other day
said you should be seeing (ideally) 13.5 to 13.7 on secs
(at idle with nothing else turned on when warm)
and anything above 14 is dodgey (as i understood).
Old Feb 6, 2006 | 07:46 PM
Neil S's Avatar
Neil S
Maybe I should quit whilst I'm ahead then Phil
Neil.
Old Feb 6, 2006 | 07:52 PM
Sticky.'s Avatar
Sticky.
You mean wait til he is out
Heat gun, set to low mate & a knife & it will come off, if any glue use UPVC cleaner and polish.....Job done
Old Feb 6, 2006 | 08:33 PM
pee vee's Avatar
pee vee
Neil.
Graceland's Avatar
Graceland
Team HOTHOT!
Cheers boys
Neil - optimal voltage is 14.1 volts
Phil - Secs monitor ideally should be showing 13.6 volts, if you take into account for the 0.5v drop over the shonky old ford wires
i think it may be my battery thats on its way out as the car struggles to start if left for more than 5 days without been started another 60 quid
Old Feb 6, 2006 | 08:55 PM
pee vee's Avatar
pee vee
Cheers boys
ah right, mine shows 13.5 so close enough i guess!
Mr S1's Avatar
Mr S1
The joys of Cosworth ownership Gracie
Old Feb 6, 2006 | 10:40 PM
Graceland's Avatar
Graceland
Team HOTHOT!
enjoyed it for over a year now
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Orion_Gav
Sep 29, 2015 04:50 PM
