Anyone got any pics escos with 30mm or 35mm springs
Hi as stated was going to get coilovers. But gone of that idea my car has got spax shocks allready and Iam not happy with the hight at the rear. Ive seen woodford sell chassis dynamics 30mm . Thanks
Personally I've got Ahmeds spec Leda springs and the ride and feel is spot on but the height is probably only been lowered 20mm.
I think Esc Cos's look there best with a slightly higher rear... excessively lowered Esc Cos's can look wrong.
too low also can lead to broken driveshafts as i found out!!
the bayjoo (leda) springs paul refers to are spot on and they drop the car 10mm which is maximum drop on standard rims.
We both run Koni's and Ahmed's spec springs
Get them from Rainbird;- Springs £160 the set and konis at £310 the set
Quailty ride never crashes or knocks etc its just spot on and very stable at high speed
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
