how do u test a lamda- oxy sensor?
Old Feb 6, 2006 | 01:39 PM
rs cos's Avatar
rs cos
Default how do u test a lamda- oxy sensor?
in school boy explanation how doyou test these as i think
mine is not working rite when it gets hot!
Old Feb 6, 2006 | 01:57 PM
richm's Avatar
richm
wideband or narrow-band sensor?
Old Feb 6, 2006 | 02:21 PM
rs cos's Avatar
rs cos
std sensor on downpipe of large turbo escort cosworth ( narrow band )
Old Feb 6, 2006 | 03:14 PM
richm's Avatar
richm
you can test the actual sensor itself with a gas blowtorch (if it's a Zirconia type sensor) and a multimeter
http://www.fpuk.co.uk/technical/ttl2.htm
BUT, please check with Stu first to see if the EsCos standard one is Titania construction, as I don't think it works the same way with the blowtorch test..
http://www.fpuk.co.uk/technical/ttl1.htm
Old Feb 6, 2006 | 03:28 PM
rs cos's Avatar
rs cos
I see the titania version goes from 1-5volts i think cosworths on narrow band work between -1 to +1. can someone verify this?
Old Feb 6, 2006 | 03:54 PM
rs cos's Avatar
rs cos
btt
Old Feb 6, 2006 | 04:53 PM
Rick's Avatar
Rick
they are narrowband, 0-1v.
Old Feb 6, 2006 | 05:58 PM
richm's Avatar
richm
but some titania sensors are 0-1V output too... I have a sneaking suspicion the standard 12mm thread (mounted in the turbo exhaust housing) Cosworth ones may well be.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
