Escos Intermittent Missfire Prob ???
Old Feb 6, 2006 | 08:46 AM
AlexD's Avatar
AlexD
Post Miester !
Default Escos Intermittent Missfire Prob ???
I have a intermitten misfire prob in the Escos, I have checked the Idle control valve and all the wires round the coil....
Is there much difference between the escos and my 89 sapph sensor wise ?? or anyone else had a similar prob ?
Cheers,
Al........
Old Feb 6, 2006 | 07:54 PM
Damo V's Avatar
Damo V
Is the ECos LT and the saph 4B??
Try the crank sensor BUT my money would be on the loom plugs below the N/S bonnet vent.... IF they are still there, cut the loom plugs off and solder it all together...
Old Feb 6, 2006 | 08:35 PM
Simon Day's Avatar
Simon Day
This job, as unpleasent as it seems is a must for an escos owner and is on my list (Damo gave me that advice last year and I still have'nt got round to it. ), in the mean time try disconnecting the plugs, cleaning and reconnecting them with lots of grease.
Old Feb 6, 2006 | 08:41 PM
Gregs's Avatar
Gregs
Try the crank sensor BUT my money would be on the loom plugs below the N/S bonnet vent.... IF they are still there, cut the loom plugs off and solder it all together...[/quote]
yes mine were all green and corroded why ford put them there i will never know!
dingy cut mine out and soldered them back together and shrink tubed them top job.
Old Feb 6, 2006 | 10:01 PM
Damo V's Avatar
Damo V
all the time those loom plugs are present... You are running the risk of melting a piston.... THAT will be expensive
Old Feb 6, 2006 | 10:30 PM
Simon Day's Avatar
Simon Day
- I know Damian and I just hope I never end up with the "I told you so" - I will try and make time this weekend (between all the rugby) I have that and the fuse box to do.
Old Feb 7, 2006 | 07:51 AM
AlexD's Avatar
AlexD
Post Miester !
Cheers for the info, i was thinking it might be the phase sensor, i took it out last night, but it looks ok tbh..
Will try the loom plugs first then.......
Al............
Old Feb 9, 2006 | 03:49 PM
trotty's Avatar
trotty
christ you've got me worried now guys!!!
where exactly are the plugs that your on about so i can sort mine??
Old Feb 9, 2006 | 06:21 PM
Damo V's Avatar
Damo V
Next to the power steering fluid reservoir, Smack bang below the bonnet vent
Old Feb 10, 2006 | 08:17 AM
trotty's Avatar
trotty
nice one damo!
i'll check it out tommorrow.
Old Feb 10, 2006 | 02:39 PM
MATCOS's Avatar
MATCOS
Mine did the same-had loom plugs removed by Mark Shead-not an expensive job-has been OK since
Old Feb 10, 2006 | 04:40 PM
Danny-p's Avatar
Danny-p
what do these loom plugs do
Old Feb 10, 2006 | 06:51 PM
Damo V's Avatar
Damo V
Join the engine loom and car loom together
Old Feb 16, 2006 | 09:10 AM
AlexD's Avatar
AlexD
Post Miester !
I am going to cut these out tomorrow
Solder and heat wrap the best ??
Al.........
Old Feb 16, 2006 | 10:33 AM
gurnE's Avatar
gurnE
Al.........
I recommend a couple of scotchlocks
Heat shrink mate. Heat wrap is what you've got wrapped round your downpipe
Old Feb 16, 2006 | 10:51 AM
AlexD's Avatar
AlexD
Post Miester !
lol.. thats what i meant, not lookin forward to it,there is loads of wires
All fun on these shonky fords
Al.........
Old Feb 16, 2006 | 12:00 PM
trotty's Avatar
trotty
i'm guessing you need to disconnect the battery to do this job??
Old Feb 16, 2006 | 12:03 PM
Damo V's Avatar
Damo V
yes and do just one wire at a time
Old Feb 16, 2006 | 12:58 PM
gurnE's Avatar
gurnE
No real reason why as the wires are low tension and would only be live with the ignition on but as a safety precaution, yes you should disconnect the battery
Old Feb 16, 2006 | 04:20 PM
trotty's Avatar
trotty
thanks again guys!!
job for the weekend!!
Old Feb 16, 2006 | 05:11 PM
ian rst's Avatar
ian rst
Mine has just started misfiring for about 5 secs first start of the day, only if i have left it running before i turned it off. Could this be linked with these multi plugs your talking about?
Old Feb 16, 2006 | 05:25 PM
Damo V's Avatar
Damo V
Either way ditch them
Old Feb 16, 2006 | 08:00 PM
dave cos4x4's Avatar
dave cos4x4
could you not make the plugs good then tape then up really good to stop the water getting in etc....
not really that bothered as mine have already been done.
Old Feb 18, 2006 | 03:23 PM
AlexD's Avatar
AlexD
Post Miester !
Plugs are cut out, was a bit tricky, and missfire has gone
Cheers for the info guys
Al............
gcfcos
59
Oct 6, 2015 05:04 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Rammer46
Sep 18, 2015 08:31 AM
gcfcos
88
Sep 15, 2015 03:48 PM
Mickeystewart
Sep 9, 2015 04:04 PM
