Different plenum spacer!!!!!
Old Feb 5, 2006 | 02:06 PM
Default Different plenum spacer!!!!!
Just bought a car (not goin to say anymore on it so dont ask) that has the spacer between the head and inlet manifold ...Basically an inch thick metal gasket!......Apparently it works You heard of this guys i thought the spacer was on the plenum LOL.
Old Feb 5, 2006 | 02:09 PM
Benn 304R's Avatar
Benn 304R
Dont know, but suprised you wasnt at the piston heads meet, loads of ferraris there
Old Feb 5, 2006 | 02:10 PM
Danny B's Avatar
Danny B
depends on the application, some tuners use them to help prevent heat soak into the inlet, would nheed to know what engine it it to knoe if applicable though,
Old Feb 5, 2006 | 02:11 PM
Danny YB of course!
Old Feb 5, 2006 | 02:17 PM
Danny B's Avatar
Danny B
Originally Posted by Bosch-Man
Danny YB of course!
What ya think I am , fuckin mind reader!!! you change your dreams 3 times per night!
back to ya spacer, aint got a clue.
Old Feb 5, 2006 | 02:18 PM
Danny all my dreams are YB ....ventured over to the RB26 but soon got rid and never tempted to go back
Old Feb 5, 2006 | 03:20 PM
Replica's Avatar
Replica
doesnt increasing the port length make the air flow faster a bit like how a riffle barrel works ?
Old Feb 5, 2006 | 04:15 PM
Replica...you know you might be on to something there.....Tuners?
Old Feb 6, 2006 | 10:34 AM
BTTT!
Old Feb 6, 2006 | 11:12 AM
Stu @ M Developments's Avatar
PassionFords Creator
Its normally a plate made from a low conductive material used to isolate the inlet from heat. Many BMW's use this method as std.
Old Feb 6, 2006 | 11:26 AM
whitneyd's Avatar
whitneyd
It also increses runner length which helps make more torque down low but I hear it hurts high RPM performance.
Old Feb 6, 2006 | 11:29 AM
Rick's Avatar
Rick
A lot of those theorys go out of the window when ur talkin forced induction.
Old Feb 6, 2006 | 11:43 AM
foreigneRS's Avatar
foreigneRS
Testing the future
making it narrower would make it go faster
showing your excellent knowledge of basic physics again phil
Old Feb 6, 2006 | 11:52 AM
whitneyd's Avatar
whitneyd
But remember the boost has lag.
Old Feb 6, 2006 | 12:01 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
sarcasm at its finest
Old Feb 6, 2006 | 12:03 PM
big_wig_074's Avatar
big_wig_074
remember to rifle it then as well,otherwise its just a gun!
Old Feb 6, 2006 | 12:06 PM
dumped's Avatar
dumped
why did ex owner say it was there? any other obvious reason in the engine bay why it is there as my car has one but for a very different reason.
Old Feb 6, 2006 | 12:51 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
I reckon on it being a manifold insulator too! We used to make loads and loads of these for lots of different cars (there were even a number of race teams which bought them)
Only ever made a few YB (all 3/4" IIRC) ones though which look like:
Most of the spacers were 1/4" thick (6.4mm): In comparison to a normal gasket at about 0.6mm thick the 6.4mm spacers would conduct between two hundred and a thousand times less heat.
Old Feb 6, 2006 | 02:19 PM
Vic's Avatar
Vic
Genesis Engineering
hi
why did you stop making them for YBs? they dont work?
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
