boost question??
Old Feb 5, 2006 | 12:58 PM
martinmace's Avatar
martinmace
Default boost question??
cleaned the car this morning and gave the engine bay a bit of a polish to and i found what seems to be a bleed valve under the top boost hose which obviously is connected to the amal valve etc,it is fully closed as the engine was rebuilt 700 miles ago although it is boosting at 10psi is this normal and can i use this to adjust the boost safely,not really sure if a bleed valve is basically a boost adjuster as all bleed valves i know of are brass and this one is silver with a blue top ?? any help on this please
Old Feb 5, 2006 | 04:52 PM
ballin's Avatar
ballin
could be a manual boost controller - get a pic.
and no, you cant just adjust it for more boost - it needs doing by a tuner with adequate fueling adjustments!
Old Feb 11, 2006 | 09:18 AM
ivorbiggun's Avatar
ivorbiggun
Take heed of the above. If you don't and mess around with it yourself, you can say a very fast good bye to that new engine of yours.
Old Feb 11, 2006 | 09:38 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
As above, don't mess with it. Let a tuner do it, so that the fuelling can be checked.
Also, if it is Silver/Blue, I would imagine that its Alloy. These aren't ideal due to the fact that they are affected by heat. Brass is better!
Old Feb 11, 2006 | 11:39 AM
Oranoco's Avatar
Oranoco
DO NOT TAMPER WITH IT!!
IT WILL END IN EXPENSIVE TEARS
Old Feb 11, 2006 | 10:13 PM
martinmace's Avatar
martinmace
i have left it alone got it booked into power engineering next friday
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
