my sapph cossie 2wd engine diy build
Old Sep 18, 2003 | 01:29 PM
Mark_w's Avatar
Mark_w
Default my sapph cossie 2wd engine diy build
all coming along nicely,performed a dummy bottom end engine build to measure deck height,and then piston dish volume and head combustion chamber volume to work out cc's....ive got a excellent comp ratio tool and will put a link up for the download later.....had pistons machined to get my required ratio and now should be ready next week....total cost so far is £1520 which includes.......
block- pressure test,refaced and rebored then chemical clean.
head -pressure test,skimmed,chemical clean,new guides/seals,valves lapped,new studs,and reassembly.
sump-chemical clean,steel sump plug insert fitted.
crank checked
mahle .5 o/s pistons
full grp a gasket set
oil pump
mains/big/small ends bearings/big end bolts
cam belt and tensioner
there are a few bits ive still got to get but not urgent as im taking my time and getting it perfect....heres a few pics,theres one of the engine in my spare room (1st floor flat )as i got pissed off up/down to look at pdf workshop manual so carried it upstairs that was ok it was the carrying the full bottom end down the stairs on my own that nearly broke my back...what you reckon????
Old Sep 18, 2003 | 01:45 PM
Mark_w's Avatar
Mark_w
link to excellent free compression ratio tool.......................
http://www.maverickracing.co.uk/compratiosoft.htm
mark
Old Sep 18, 2003 | 02:08 PM
lamar69er's Avatar
lamar69er
how much did u pay for the pistons? where from? and wot machining did u do to them?
Old Sep 19, 2003 | 02:50 PM
Stu @ M Developments's Avatar
PassionFords Creator
Looking good mate
Old Sep 22, 2003 | 08:06 PM
Mr RS500's Avatar
Mr RS500
I HOPE YOU DONT NEED TO RESPRAY YOUR CAR OR YOUR ROOM WILL BE A RIGHT MESS ,LOL
ONLY JOKEING , MOTOR LOOKS GOOD MATE AND NICE TO SEE YOUR DOING IT YOURSELF
Old Oct 3, 2003 | 06:51 PM
Mark_w's Avatar
Mark_w
update....engine built now and in,heres a few pics...had cam cover sandblasted and sprayed with engine enamel.....just gotta do the finishing touches tommorow morning and hopefully its running in the afternoon..
Old Oct 4, 2003 | 10:32 AM
cossiemen's Avatar
cossiemen
Whassup
looks great mate !
Old Oct 4, 2003 | 10:59 AM
Rhys's Avatar
Rhys
Mice one mate looks top!!!
Is it rebuilt to Std spec!? And is it running now?
Old Oct 9, 2003 | 05:30 PM
Mark_w's Avatar
Mark_w
it was running stg3 before rhys,but have put yellows and stg1 chip back in for the moment and going stg3 again with new chip....the bottom end is built standard apart from pistons which i machined to 7.6/1 ready for when i go to greens with the t34...i got it running last sunday and it sounds sweet,have done 100 miles now at no more than 3000rpm and only problem ive had was a leaking washer on banjo bolt for turbo water return,which was easily fixed with new washers,but apart from that it sounds good....heres some pics...
mark
Old Oct 9, 2003 | 09:52 PM
neo's Avatar
neo
good work carried out there, what did the rebuild cost you in total in the end then ?
Old Oct 25, 2003 | 03:51 PM
Jim Green's Avatar
Jim Green
Nice rebuild, Glad you took the time to have the block checked out properly and pressure tested and chemically cleaned.
As you know mines going back together as we speak.
I've worked out your "Cam Sprocket locking tool" Just made up up in the garage, and put it into place ready for dropping the head on. Just waiting for the Exhaust and Inlet Gaskets to arrive on tuesday, Hopefully we'll be running tuesday night.
I see another session of burning the midnight oil coming on.
Jim
Old Oct 26, 2003 | 03:49 PM
Mark_w's Avatar
Mark_w
heres a better pic jim....you will have to come to the west suusex meet next sunday if your cars up and running
Old Oct 1, 2004 | 02:41 PM
cozzie4d's Avatar
cozzie4d
nice engine, maybe some nice blue hoses and alu will make the finishing touch
But I can imagine you've gone through your spares with rebuilding the engine, so good luck.
Old Oct 1, 2004 | 02:50 PM
Sticky.'s Avatar
Sticky.
Looking good mate
Cam cover looks well, after being sandblasted
Old Oct 1, 2004 | 03:14 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Nice work
Old Oct 1, 2004 | 03:20 PM
dvid's Avatar
dvid
west sussex? good to see others from my area here!
Old Oct 1, 2004 | 04:10 PM
lamb chops's Avatar
lamb chops
Jim
Whats up with your beast then Jim? I take it your back in the UK then?
Top job by the way Mark Would love to have ago myself with mine if\ when I need too.
Old Oct 1, 2004 | 05:02 PM
wimwerf's Avatar
wimwerf
your pretty handy doing all these things yourself
Karl 3dr
102
Oct 14, 2016 08:17 PM
RsS2daz
Aug 14, 2015 05:26 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
